king pin bearing broken up :'(
- markyp2000
16 Apr 2013 17:46 #68825
by markyp2000
Replied by markyp2000 on topic king pin bearing broken up :'(
Another problem i see may result in a new front axle :'( the bottom race goes in and is not a tight fit as i can turn the race while in the axle by hand and it falls out what do you guys think
- markyp2000
18 Apr 2013 12:53 #68961
by markyp2000
Well fitted new axle tube
Removed front axle took apart 2 axles ie put my diff and hubs on as i new thay was ok refitted all in 4 hours on my back which i think was good going and the compleat axle only cost £100
and no more wheel wobble which stared a few month ago so next time it wobbles ill be looking at it right ways
- Tadpole
18 Apr 2013 15:18 #68967
by Tadpole
Replied by Tadpole on topic king pin bearing broken up :'(
Good news Marky .................
18 Apr 2013 15:45 #68968
by Obarno
Replied by Obarno on topic king pin bearing broken up :'(
Markyp2000. I would try some Locktite stud and bearing retainer - probably will hold it in place without any problem. As regards the bearings, I changed one yesterday and the bottom bearing was badly damaged and bent, and the seat came out in 2 pieces. There was oil leaking from the big seal which drew my attention to it, but equally there was no play in the hub at all. There was a small amount of wheel wobble which did make me suspicious.
- markyp2000
18 Apr 2013 16:05 #68971
by markyp2000
Thats what mine was like but id rather do the job right and nobits gonna hold up seeing as im a mechanic it would go against my better judgement
19 Apr 2013 10:51 #69007
by kirkynut
Replied by kirkynut on topic king pin bearing broken up :'(
When I put a replacement front axle on mine the kingpins in it were seized and the bearings really rusty but I drove it like that for a few weeks before getting the time to change the wheel bearings and kingpin bearings. I had no wobble despite all the rust but they were in one piece!
I empathise about changing the axle on the floor on your own!
Why did you have to do it in the first place though? I don't remember reading of you telling us, but I do miss things!
Time to create page: 0.160 seconds
