king pin bearing broken up :'(
  • markyp2000
13 Apr 2013 13:17 - 19 Apr 2013 17:01 #68618 by markyp2000
king pin bearing broken up :'( was created by markyp2000
Has any one come across the above i went to change the half shaft oil seal simple job well so i thought when i removed the compleat hub the lower bearing fell out to be exspected as it at the bottom then started the dirty proses of cleaning it out and all the parts and then i found this :ohmy: :angry: :unsure: :(
Has any one seen this before the bearing race broke up and the center of the beaing has broken also the bearing cage damaged :angry: :(
Last edit: 19 Apr 2013 17:01 by markyp2000.
  • Tadpole
13 Apr 2013 17:05 #68631 by Tadpole
Replied by Tadpole on topic king pin bearing broken up :'(
Was there no indication of bearing failure Marky ........................ :(
13 Apr 2013 19:34 #68636 by j999pre
Yes had similar looking bits drop out before. Also had the bearing seize onto the kingpin. Proper sod to get out.
It usually its down to water ingress.
Grey pick up Jimny
  • markyp2000
13 Apr 2013 20:51 #68639 by markyp2000
Replied by markyp2000 on topic king pin bearing broken up :'(
Had a bit of wheel wobble for a few month but i just thought it was wheel balance lol
  • mudman
13 Apr 2013 21:46 #68647 by mudman
Replied by mudman on topic king pin bearing broken up :'(
thats how mine looked both sides when i 1st got it i done king pin bearings and wheel bearings both side sitll got a small amount of movment on the near side but i cant feel it while driving so im just going to leave it untill somthing brakes as i cant work out what it is :lol:
  • supergaz
14 Apr 2013 07:57 #68653 by supergaz
Replied by supergaz on topic king pin bearing broken up :'(
Yes, my bearing has broken up into loads if pieces, then chewed up the kingpin on the hub whilst driving slowly home, it was a bugger to get the kingpin out.
Time to create page: 0.231 seconds
