not shaw of something ?
- Jackdelves
01 Apr 2013 18:16 #67558
by Jackdelves
not shaw of something ? was created by Jackdelves
hi
as you may have read have just changed king pins ect.used the picture guide on this web site very handy.when i did the job i found i needed to remove a 3rd pipe assembly not shown on the guide.this sits just proud of a wot looks like a cogged wheel.this wheel as i call it gets in the way for access to the 4 bolts but i managed it ok.just wondered wot this assembly is for.
thanks .
thanks .
- vitara_mad
01 Apr 2013 18:17 #67559
by vitara_mad
Replied by vitara_mad on topic not shaw of something ?
does your jimny have abs ???
- reaper
01 Apr 2013 18:18 #67560
by reaper
Abs ring
Replied by reaper on topic not shaw of something ?
Nailed itvitara_mad wrote: does your jimny have abs ???
Abs ring
- Jackdelves
01 Apr 2013 18:23 #67562
by Jackdelves
Replied by Jackdelves on topic not shaw of something ?
yes it does
- markyp2000
01 Apr 2013 18:25 - 01 Apr 2013 18:30 #67563
by markyp2000
Replied by markyp2000 on topic not shaw of something ?
4 bolts ? What 4 bolts are you on about
when i did mine i just removed the caliper steering joints hub pipes and ball dust seal and then the top and bottom king pin pins and took th hole lot off
Last edit: 01 Apr 2013 18:30 by markyp2000.
- Jackdelves
01 Apr 2013 18:32 #67565
by Jackdelves
the 4 bolts holding the front assembly together just behind wot i think is the abs ring.
Time to create page: 0.204 seconds
