what to use to make rear quieter
08 Mar 2013 23:10 #65025
by facade
Replied by facade on topic what to use to make rear quieter
Anything that goes inside the car must not smell.
the cheaper products on eBay stink blind :ohmy:
Underseal will smell for weeks.
- goatboy
09 Mar 2013 10:39 #65041
by goatboy
Replied by goatboy on topic what to use to make rear quieter
I sound proofed the whole rear of a mitsubishi colt I used to have. Including the floor pan of the boot and both rear arches.
First a layer of the stick on noise damping sheets (like Dynamat but I used much less expensive stuff)
www.caraudiodirect.co.uk/silent-coat-mat-bulk-pack.html
And then a layer of foam noise barrier a bit like this
www.caraudiodirect.co.uk/sil-isolator6-b...ator-6-9-sheets.html
It took a day and quite a lot of swearing to get it all in but it did reduce road noise quite considerably
There are loads of different options on materials.
www.caraudiodirect.co.uk/deadening/
I would avoid the paint on stuff as it takes a while to dry and smells quite bad apparently.
- happypig
09 Mar 2013 12:18 #65045
by happypig
Replied by happypig on topic what to use to make rear quieter
Go back to 1977, attend loads of punk and heavy metal gigs for at least 15 years until you start to suffer from hearing loss.
worked for me....
worked for me....
- JivingDaddy
09 Mar 2013 12:25 #65046
by JivingDaddy
Replied by JivingDaddy on topic what to use to make rear quieter
Nowt wrong with a bit of Jimny road noise, drowns out the CO's constant jabbering. :S
- little jimny
09 Mar 2013 17:26 #65069
by little jimny
Replied by little jimny on topic what to use to make rear quieter
given that the boot floor is prone to rust is it a good idea to cover it with self adhesive sound deadening? Wouldn't it just trap any moisture and make it rust out of sight?
Time to create page: 0.168 seconds
