Drive belts HELP...!
  • Mala43B
18 Feb 2013 20:32 #63080 by Mala43B
Drive belts HELP...! was created by Mala43B
Hi guys, I need some help.
My fan belt snapped the other day, the belt that drives the alternator & water pump.
I got a new belt (Thanks Martin for providing the part number) but seeing as though you have to take the power steering belt off in order to fit the fan belt I thought it would be a good idea to replace that too.
I cut off the power steering belt and after a few bad tempered outbursts I managed to get the alternator to move on its pivot so I could fit the and re tension the fan belt.
However I can't fit the power steering belt as I can't seem to work out how the belt tensioner works, i.e how to adjust the tension pulley so that I can fit and tension the belt.
i have the workshop manual but it is vague to say the least.
Can anyone explain how to adjust the power steering belt pulley, any pictures would be of great help.
Thanks in anticipation guys.
  • reaper
18 Feb 2013 20:45 #63081 by reaper
Replied by reaper on topic Drive belts HELP...!
It should be just a case off loosening a bolt and this lets it swivel on an elongated hole , however when i did mine i had to loosen both bolts as the pivot bolt was to tight to let the pully move
  • Jimñy aaron
18 Feb 2013 20:48 #63082 by Jimñy aaron
Replied by Jimñy aaron on topic Drive belts HELP...!
Is it not a strechy belt?
  • Mala43B
18 Feb 2013 20:59 #63086 by Mala43B
Replied by Mala43B on topic Drive belts HELP...!
Jimñy aaron wrote: Is it not a strechy belt?
It's not a strechy belt no.........?
  • Jimñy aaron
18 Feb 2013 21:04 #63087 by Jimñy aaron
Ok well the pump must move then i cant remember its been a while since iv changed one.
  • markyp2000
18 Feb 2013 21:17 #63090 by markyp2000
Replied by markyp2000 on topic Drive belts HELP...!
Is it twin cam or single cam also look in the search section im shore its been asked before
Time to create page: 0.396 seconds
