inverter for compressor idea?
10 Feb 2013 22:36 - 10 Feb 2013 22:36 #62068
Replied by mlines on topic inverter for compressor idea?
It is but you need to allow for losses in the system. I would guess that a 1HP motor would draw more than that electricity just due to being inefficient, equally the inverter manufacturers are hopeful with their ratings. The one I looked at on Amazon said 2kw continuous but I would never like to run something at near to its maximum rating on a continuous basis.
And remember what this equates to on the low voltage side of the inverter. If you have a 2HP compressor thats 1400Watts, lets say 1800 Watts for real. On the low voltage side 1800Watts is 1800/13 = 138 Amps - which is pretty much a cable melting level.
Last edit: 10 Feb 2013 22:36 by mlines.
- Dave cc
10 Feb 2013 22:44 #62072
by Dave cc
Replied by Dave cc on topic inverter for compressor idea?
As Martin has very well exsplained forget running a 240v compressor via a inverter would be a horrible set up i paid £100 for a ARB comp with diff lock and compressor switches
- darthloachie
10 Feb 2013 22:44 #62073
by darthloachie
Replied by darthloachie on topic inverter for compressor idea?
you could just fit a big tank and charge it up before you go out
- jimnybob
11 Feb 2013 08:19 #62104
by jimnybob
Replied by jimnybob on topic inverter for compressor idea?
Yeah I spose it would be prone to melting something under the bonnet. If I get an arb pump would someone be able to help me with fitting a tank pwease? I've got a fire extinguisher that I could use.
Time to create page: 2.946 seconds
