body lift
- Chris the Phys
03 Feb 2013 20:21 #60788
by Chris the Phys
body lift was created by Chris the Phys
How easy is a body lift
- iloveics
03 Feb 2013 21:11 #60806
by iloveics
Replied by iloveics on topic body lift
I haven't done one personally, but from others have told me there not to bad to do.
But a suspension lift is easier.
03 Feb 2013 21:26 #60808
Replied by mlines on topic Re: body lift
The nice thing about a body lift is that it doesn't affect the handling and you can add a spring lift later for maximum height.
Sent from my HP Touch pad using Tapatalk
- badboy-jimny
03 Feb 2013 21:30 #60809
by badboy-jimny
Replied by badboy-jimny on topic Re: body lift
Can you do both spring and body lift without to much messing about with longer brake lines and so on?
- winter
03 Feb 2013 21:37 #60811
by winter
Replied by winter on topic body lift
it a bit of cake to do body lift unbolt body theres 8 bolts that hold body to chassis then undo steering uj under bonnet you will need a spacer making for it after you have done body lift check wires n pipes are not pulling tight when jacking up body undo brake pipis from bracket which goes to the chassis at rear thats it o yer you need to extend 4x4 lever as you want get it into 4l only took me bout two hours with tea brakes to i done a 2" body lift with a 3.5"springs n shocks hope this has helped
Time to create page: 0.479 seconds
