Engine management light on all the time
02 Jan 2013 20:48 #56960
by facade
Replied by facade on topic Engine management light on all the time
Inlet leak?
What is the idle speed?
Check that the rubber pipe from the side of the inlet manifold to the vacuum valves under the battery is intact.
- suzuki jimny fella
02 Jan 2013 21:51 #56974
by suzuki jimny fella
Replied by suzuki jimny fella on topic Engine management light on all the time
i noticed my light flash on and off it happend about 5 times in 2 years now is that normal of it flashing thanks
- Barnyzuki
03 Jan 2013 13:12 #57042
by Barnyzuki
Replied by Barnyzuki on topic Engine management light on all the time
Mine does this, about 30 minutes after getting up to full operating temperature the idle dips and feels like it`s going to stall, then the engine management light comes on.
Idle goes back to normal, car drives as normal, I ignore it completely.
Leave it overnight and the light goes off.
Repeat process
Repeat process
- peter broadbent
05 Jan 2013 18:06 #57206
by peter broadbent
Replied by peter broadbent on topic Engine management light on all the time
idle speed when started cold is about 1400 and drops to 1000 when warmed up, cant see anything wrong with vacuum pipe from manifold!!!
any more ideas please
05 Jan 2013 18:49 #57207
Replied by mlines on topic Engine management light on all the time
See attached
- mattssiow
24 Jun 2019 11:25 #210253
by mattssiow
Replied by mattssiow on topic Engine management light on all the time
Did you get any joy with this, I have same problem
Time to create page: 0.264 seconds
