Reason for low roof rack limit?
19 Nov 2018 19:26 #197808 by Bill Portland
Is the 30kg per bar or total?
I have a 31kg kayak, should be ok?
Sent from my Lenovo YB1-X90F using Tapatalk
19 Nov 2018 20:38 #197818 by Scimike
I believe its 30kg total. The roof rails on a Jimny are not that strong, more for show in my humble opinion. That said it should be fine with 31kg on them as if they are rated at 30kg they will have a safety margin above this. However its your call to exceed the 30kg limit as Suzuki must have put it there for a reason.
The following user(s) said Thank You: Bill Portland
20 Nov 2018 04:20 #197826 by Lambert
Don't forget to factor in the weight of any additional support structure like cross bars.
20 Nov 2018 21:42 - 20 Nov 2018 21:44 #197870 by kirkynut
I wonder if they kept it low to pass the old elk test with it loaded. Remember when the old SJ famously failed it when it was a bit of a farce?
www.bigjimny.com/index.php/forum?view=topic&catid=6&id=61191
Last edit: 20 Nov 2018 21:44 by kirkynut.
21 Nov 2018 07:13 #197881 by facade
If you do put something big and light up there, and it acts like a sail/wing it will break the plastic ends and pull the whole lot off when you drive at speed.
21 Nov 2018 18:01 #197933 by Riccy
I did that (or similar)...
Strapped some old plastic twinwall roofing sheets to the top. no wider than the car but nearly as long as it. OK at low speeds, but anything over 30 set the board off flapping up and down, which in turn moved the whole car up/down. very scary :laugh:
oddly though the plastic bars/feet never broke, despite being repeatedly overloaded or used as above
Time to create page: 0.446 seconds
