Front drive shafts oily ?
  • g8ape
14 Nov 2012 16:40 #53244 by g8ape
Front drive shafts oily ? was created by g8ape
A friend is as I type looking at an 2001 ish Jimny to possibly buy and has noticed an amount of oil/grease on the wheel end of the front drive shafts where it attaches to the back of the wheel, the semi spherical arrangement/ coupling.
Is it normal to see oil/grease there?
  • Sponnie
14 Nov 2012 17:49 - 14 Nov 2012 17:51 #53251 by Sponnie
Replied by Sponnie on topic Front drive shafts oily ?
No its not. There are perhaps a million posts on this, but basically the spherical knuckle/Swivel joint has a seal to stop the oil coming out of the Diff, this more than likely needs replacing.
Also the Kingpin/Swivel bearings could also be on their way out, in particular the bottom one.
A messy job but not hard.
Look in the Bigjimny shop it has all you need.
www.bigjimny.com/store/index.php/service...g-kit-koyo-/p_6.html
Has the Jimny been offroaded much?
Last edit: 14 Nov 2012 17:51 by Sponnie. Reason: inserting link
14 Nov 2012 18:03 #53256 by mlines
Replied by mlines on topic Front drive shafts oily ?
As has just been said, very common.
Suck air in over your teeth, make lots of tut tut noises and make a low offer.
Then fix it for £23.75 from the store ;)
  • stonkn
14 Nov 2012 18:32 #53258 by stonkn
Replied by stonkn on topic Front drive shafts oily ?
Hi everybody,
It was me looking at the car !! Basically an 05 plate with 40k on it. It does not look to have had a hard life - the interior/exterior in good order but the underside is in need of a waxoyl !! The spheres are wet on the bottom havles - I could see the seal with bolt heads around it - there looks like a small build up of a dark brown 'greese; at the bottom part of the seal. I could not detect a steering wheel shimy but thought the brakes were a bit 'light'. The steering was also very light' but these could be std as this is my first Jimny experiance?
Marco
14 Nov 2012 21:05 #53272 by mlines
Steering tends to be light.
The "seal" you can see is not the seal we are talking about, its a small inner one.
If its just grease then you will be ok, its when its dripping that you have an issue.
  • stonkn
15 Nov 2012 09:30 #53303 by stonkn
Thanks Martin,
The spheres were only 'wet' on the bottom halves but the NS apeared worse than OS. They were fairly grimey & the seal (that I could see) did not look fantatic. However, I checked out 4 wheel drive engagement & all seemed OK.
M
Time to create page: 0.256 seconds
