Horn Connections
  • Smoggy
10 Nov 2012 12:25 - 10 Nov 2012 16:56 #52773 by Smoggy
Horn Connections was created by Smoggy
Hi all,
Does anyone know how to get to the horn connection wires at the rear of the steering wheel. When I removed my steering shaft to fit the extended one, my son spun the wheel round and round and now the horn doesnt work :(
I have traced the fault back to the blue/red solenoid return to the horn button(s) or the horn button earth return but I'm not sure how to get at the wires at the rear of the steering wheel.
Cheers.
Last edit: 10 Nov 2012 16:56 by Smoggy.
10 Nov 2012 14:56 #52782 by facade
Replied by facade on topic Horn Connections
You are in trouble :(
There is a ribbon tape connector thingie in a cassette behind the wheel that breaks if the wheel is turned more than 2 1/2 turns either way.
The wheel has to come off for access.
  • Smoggy
10 Nov 2012 16:54 #52789 by Smoggy
Replied by Smoggy on topic Horn Connections
Wish I had asked the question last night before I checked the horn, horn earth, connector between the solenoid and horn, the solenoid itself (to gain access to which I had to remove half the dash) and finally traced it back to the contactor coil which as you quite rightly said is behind the steering wheel and airbag assembly :( :( :(
Opened up the coil and sure enough the ribbon had snapped from one of the terminals :angry:
10 Nov 2012 17:15 - 10 Nov 2012 17:16 #52794 by dirtydogz
Replied by dirtydogz on topic Horn Connections
Don't we love our kids they make life so much fun the little :evil: .
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 10 Nov 2012 17:16 by dirtydogz.
  • markyp2000
10 Nov 2012 18:02 #52808 by markyp2000
Replied by markyp2000 on topic Horn Connections
if id seen this earlyer id of poped th4e the scrap yard where there are to i no of probs only be £20 cheaper than ebay or cam
  • Smoggy
10 Nov 2012 18:16 #52814 by Smoggy
Yeah thats a good idea mate, think i'l pop to the local yards tomorrow. Good news is I made myself a cheap steering wheel removal tool, so should come in handy.
Time to create page: 0.168 seconds
