Removing A God Damn Steering Wheel! (With Pics)
  • Paul4x4
02 Aug 2012 13:28 #45357 by Paul4x4
facade wrote: Can't you make an extractor?
There are 2 threaded holes in your picture that take bolts to extract the wheel with a bar across the column. Drill a hole in the bar and put a nut & bolt through it, then loosen the nut whilst holding the bolt to pull the wheel off the correct way.
Yeah, that's how it should be done. Takes 15 minutes max to make an extractor of some sort, and the wheel will pop off without any wd40, heating and other magic tricks. ;)
  • Countryboy03
02 Aug 2012 16:08 #45370 by Countryboy03
Replied by Countryboy03 on topic Re: Removing A God Damn Steering Wheel! (With Pics)
Already sprayed with WD40 several times.
Does anyone know what size bolts i need to screw into the old wheel to make an extractor?
Many thanks for reply's boys.
  • markyp2000
02 Aug 2012 16:50 - 02 Aug 2012 16:52 #45376 by markyp2000
have you cut the plug on the air bag offlooking at the pics also you my need to wire in a switch for the horn cos if i remember the air bag ring behind the wheel will need to be removed to fit the boss kit
bolt may be 13mm head with 8mm thead or a 17mm bolt with a 10mm thread or it could be japanese
fine thread
Last edit: 02 Aug 2012 16:52 by markyp2000.
  • Paul4x4
02 Aug 2012 16:56 #45378 by Paul4x4
Those threads are M8.
  • jo king
05 Aug 2012 21:33 - 05 Aug 2012 21:34 #45542 by jo king
put your hands on the steering wheel 1 at 9 o'clock the other hand at 3 o'clock pulll with your left hand push with your right hand then do the opposite do this working your hands around the steering wheel
Last edit: 05 Aug 2012 21:34 by jo king.
  • markyp2000
05 Aug 2012 21:38 #45543 by markyp2000
i belive this has already been tryed as stated in other posts
Time to create page: 0.156 seconds
