Removing A God Damn Steering Wheel! (With Pics)
- Countryboy03
01 Aug 2012 20:51 - 01 Aug 2012 20:53 #45308
by Countryboy03
Removing A God Damn Steering Wheel! (With Pics) was created by Countryboy03
Bought this wheel + boss cheap:
Untitled by countryboy1962 , on Flickr
To replace this real tatty one:
Taken nut off but the wheel is seized solid on the splines.
Looked at a few youtube vids (various makes/models) and there's many a rough bastard swinging on it to remove them.
They sell steering wheel removal kits on ebay but there not particulally cheap and i only need to use it once, also none are listed as suitable for Suzuki's (although one could probably mod to suit).
There are two bolt holes to screw bolts (seen left+right in the last pic), could maybe put two bolts with a strip of metal plate across and drive it out that way?
Anyone else had this trouble
Last edit: 01 Aug 2012 20:53 by Countryboy03.
- markyp2000
01 Aug 2012 21:09 #45313
by markyp2000
Replied by markyp2000 on topic Re: Removing A God Damn Steering Wheel! (With Pics)
put the nut back on or you may end up with 2 black eyes and a nose bleed hold it at the left and right sides when it sits stright the wiggle left to right and yank like f#$k it will pop off dont hit it you will damage the tread and may be the colloum to
- Johnniehec
- Thank you received: 56
01 Aug 2012 21:12 #45316
by Johnniehec
Replied by Johnniehec on topic Re: Removing A God Damn Steering Wheel! (With Pics)
Hi, I've not done it with the Jimny but the usual method I've used is
Put the nut back on so that it's just proud of the end of the steering column then hit it sharply with a hammer. Don't know what you're going to do with the airbag though? Someone will probably advise.
Cheers,
John.
Cheers,
John.
- markyp2000
01 Aug 2012 21:15 #45317
by markyp2000
with out the airbag it will/may fail the mot after november dont hit is cos it may be a collapsable colloum
- Countryboy03
01 Aug 2012 21:19 #45318
by Countryboy03
Replied by Countryboy03 on topic Re: Removing A God Damn Steering Wheel! (With Pics)
Yeah, i did put the nut on a few threads when pulling on it :laugh:
It's seized solid, no movement on it one bit :dry:
Markyp has just told me come November it wont pass MOT but ill cross that bridge a year in September.
Anyone else any idea - pulling on it isn't going to cut it
- markyp2000
01 Aug 2012 21:25 #45322
by markyp2000
if your not going to use it again try using a heat gun want warm it up
Time to create page: 0.221 seconds
