Help me fabricate recovery points - welder wanted.
  • trextr7monkey
28 Feb 2012 16:49 #34416 by trextr7monkey
Replied by trextr7monkey on topic Re: Help me fabricate recovery points - welder wanted.
Why not use angle for the extension with box and threads on the end?
  • nicho
28 Feb 2012 18:46 - 28 Feb 2012 18:48 #34434 by nicho
dont know but could u not drill and tap the ends off the chassie one on each side sumet like a inch then use something like the above with the long shank then put a nut or drill and tap a smaller plate than the ends of the chassie u could then just drive to a welder with everthing fastened in position and weld the plate or nut to the chassie.you could then screw em in out when wonted.
Last edit: 28 Feb 2012 18:48 by nicho.
  • goatboy
29 Feb 2012 07:34 #34473 by goatboy
trextr7monkey wrote: Why not use angle for the extension with box and threads on the end?
That could work, would make it stronger I guess.
  • Bland
31 Jul 2016 08:53 - 31 Jul 2016 08:54 #170770 by Bland
These eyelets are not designed for off road recovery. They are for cars to get towed up a recovery truck beaver back or behind an AA van. You need a heavy duty eyelet that will take a shackle of say 1 ton. It needs to be bolted with a 8:8 set of bolts and big plates behind to withstand the sort of loading a stuck up to your axles mud bog applies to you jimny. If done wrongly these make do cheap fix solutions have been knon to KILL
Last edit: 31 Jul 2016 08:54 by Bland.
Time to create page: 0.135 seconds
