High Pitch Squeal
  • hathome
29 Oct 2011 14:58 #24721 by hathome
High Pitch Squeal was created by hathome
Hi again all - Sure this is not related BUT have just changed the kingpins bearings and thought I'd take the Jimny out for a quick road test. After about 10 mins I've got this horrendous squeal form something !! OK when not moving so I thought maybe the clutch slipping - but seems ok getting up our steep drive and when testing with the handbrake on :blink: Is there anything obvious I should be looking for (Anything I may have done during the bearing change?) - Thanks for your help - I'd be lost without this site
  • p1ngu32
29 Oct 2011 15:30 #24735 by p1ngu32
Replied by p1ngu32 on topic Re: High Pitch Squeal
anything gotten trapped between the disc and the back plate? stray nut or bolt? i get a huge squeel off mine when stones get wedged in there.
  • martysmith
29 Oct 2011 15:37 #24738 by martysmith
Replied by martysmith on topic Re: High Pitch Squeal
may just be back plate toutching brake disc ........fingers crossed for you
  • Dunkspeed
29 Oct 2011 15:45 #24741 by Dunkspeed
Replied by Dunkspeed on topic Re: High Pitch Squeal
I'd go for backplates too!
  • hathome
29 Oct 2011 16:09 #24747 by hathome
Replied by hathome on topic Re: High Pitch Squeal
Thanks all - I'll check it out tomorow - If its not that I'll check the ancillory belts etc - its been sitting on the drive for a fortnight now going nowhere!
29 Oct 2011 16:19 #24751 by mlines
Replied by mlines on topic Re: High Pitch Squeal
Simple check:
Drive belt slip - noise is related to engine rev level, rev the engine and see if it changes.
Drive train noise - road speed related, reving engine will not make a difference but speeding up /slowing down will.
Time to create page: 0.417 seconds
