Rocklobster - - - What use is it? Why do it?
  • Seawolfvarna
25 Jun 2011 05:52 #18243 by Seawolfvarna
Replied by Seawolfvarna on topic Re: Rocklobster - - - What use is it? Why do it?
Hi everybody
I see that here everybody is mentioning only the modifications in T-case in order to lower down your gear ratio. As I know is it possible to use also modification in axles by means of new pinion shaft and new crown ring. Did anybody use this method to lower down the gear ratio and to reduce the stresses on rear and front axles.
Please look here, what I mean: www.calmini4x4.de/538-1-Ring-Pinion-Kit_1
Yours:
Nick
  • panosd
25 Jun 2011 08:03 #18245 by panosd
At first these r&p are for sami not for jimny. For jimny are made only from him www.4xfourart.com/
and in 5.1:1 ratio. I have my cousin using them in his jimny. It is not a very good option because you will
always have to open-close your diff avery time you want to make an adjustment etc.
If you are doing a lot of miles it is not recomended.
If you have the non vvt model then you can install the vvt model diffs. This will give you a -12% reduction.
We have a friends jimny mod2002 with vvt2007 diffs and runs 235-75-15 without any other transmision
mod. The price of the vvt r&p is about 250euros per diff from a scrupyard and for the 4x4art diffs is 350e
per diff.
The costs are the same by choosing one or other but you will have more benefits by installing a sami
t-case with gears.
  • Seawolfvarna
26 Jun 2011 16:26 #18283 by Seawolfvarna
panosd wrote: At first these r&p are for sami not for jimny. For jimny are made only from him www.4xfourart.com/
per diff.
t-case with gears.
Thank you Panosd
Now I know the right way to update my Jimny. I will do it with rock-lobster or even rock-crawler.
It will be more expansive but as you said the benefits are bigger.
Cheers
  • panosd
27 Jun 2011 16:51 #18324 by panosd
Time to create page: 0.291 seconds
