K and N On Jimny
- doncarlyon
06 May 2011 12:57 #15968
by doncarlyon
Replied by doncarlyon on topic Re: K and N On Jimny
Maybe just a bigger airbox would be a better idea then to stop the heat soak?
07 May 2011 11:44 #16004
by kirkynut
Replied by kirkynut on topic Re: K and N On Jimny
If you are fitting a cone filter to a Jimny, make sure it's for on road or very dry off road use only.
The original airbox is carefully designed to be able to cope with an amount of water, when you look at the route of the rubber intake pipe and then the bowl at the bottom of the airbox which has a hole in it to allow water to run out.
You don't have to go through that deep water to splash it over the airbox and a cone filter would just allow it to get sucked through if it got a soaking.
So just be careful when offroading with one!
If you were going to go out and buy one new, maybe the money would be better put towards a snorkel?
07 May 2011 16:52 #16016
by facade
Replied by facade on topic Re: K and N On Jimny
First thing my brother does to his cars is fit a cone filter. He reckons they go miles faster, I reckon they make too much noise.
I've driven a couple, they have no bottom end at all, and I can't get them to pull away without boy racer revs and clutch slipping. ( Golf GTI and some 5 cylinder fiat saloon with a funny name)
If you do fit one, keep all the original filter and fittings, if I came to buy the car my first question would be: "Do you have the original air filter?"
- doncarlyon
11 Aug 2011 09:43 #20182
by doncarlyon
Hows it going with the filter?
- ZookFastback
11 Aug 2011 10:46 #20185
by ZookFastback
Replied by ZookFastback on topic Re: K and N On Jimny
I would not use the type of filter you are talking about because they do not filter as much grit out of the air as a standard paper filter. Because they don't filter out as many particles they can suck more air in to give slight power gains but at the risk of premature engine failure due to abrasive particles not being filtered out of the intake.
Check this well-known article out for yourself... www.bobistheoilguy.com/airfilter/airtest1.htm
- fatwelly
12 Aug 2011 07:33 - 12 Aug 2011 07:35 #20229
by fatwelly
Replied by fatwelly on topic Re: K and N On Jimny
i would sugest needs cleaning every 6 months
with kn cleaner and needs re oiling after woulds to keep dust out
note i left the old air box in for off road use
there is cold air ducting to the kn one from inner wing one from the font
ps how do i add a pic to this post
Last edit: 12 Aug 2011 07:35 by fatwelly.
Time to create page: 0.174 seconds
