Gas canister
05 Sep 2015 19:51 - 05 Sep 2015 23:03 #151390
Gas canister was created by helijohn
It's always the same.
I reach for the propane gas torch after months since last using it desperate to shift a nut (this time on the shock absorber) and the gas has all leaked out.
So what do I do to avoid losing the gas. How do you store your blowtorches?
Last edit: 05 Sep 2015 23:03 by helijohn.
- wombat
05 Sep 2015 22:16 #151405
by wombat
Replied by wombat on topic Gas cannister
Hi, if i don't intend using it for a while i disconnect the cannister and then double check by pouring some fairy liquid ,
( other brands are available !! ) and if no bubbles no leak . I have had things leak before when left attached to the gas source so always remove cannisters now,
cheers. Ian
cheers. Ian
05 Sep 2015 23:05 #151410
That's what I do but they never seem to hold the gas.
Replied by helijohn on topic Gas cannister
wombat wrote: so always remove cannisters now,
cheers. Ian![]()
- Grego
07 Sep 2015 16:59 #151494
by Grego
Replied by Grego on topic Gas canister
Think I've had the gas screwed onto mine for over 5 yrs with no problems , getting a bit low now.
Got a few partially used cans that havent leaked either,...... luck of the draw?
07 Sep 2015 17:11 #151495
Replied by helijohn on topic Gas canister
Question is do I keep the burner attached?
- Grego
07 Sep 2015 17:42 #151498
by Grego
You could try a drop of silicone oil on the seals
Time to create page: 0.277 seconds
