Something to pull my Jimny around with!!
17 Aug 2015 18:26 #149981
Replied by Daniel30 on topic Something to pull my Jimny around with!!
How you getting on with this pod Gus??
- gusthegorilla
17 Aug 2015 19:35 #149989
by gusthegorilla
Replied by gusthegorilla on topic Something to pull my Jimny around with!!
Saturday...ripped out absolutely everything electrical, 12v, 240 mains...the lot!!!
Made the following horrendous discovery :
240v mains...wire leading from hook-up plug-in point direct to a 13 amp 3 pin socket, and on from there to a double 13amp 3 pin socket...no circuit breakers, fuse box or any other form of safety device :sick:
12v: heavy gauge +/- cable following same route as mains, terminating in the biggest pieces of chocolate block you ever saw....every 12v item on board wired straight from the other side of these, once again no fuse box or safety device of any kind :sick:
To be honest, Dan, I s**t a brick when I worked it all out.....so it was onto the computer late Sat night and bought 240v consumer unit, 12v 10-way fuse box, ground busbar, battery isolator, optimate trickle charger and a truck load of terminal tackle.
Provided it all arrives in time, should have it all re-wired by end of weekend.
Apart from that...it's all brilliant
17 Aug 2015 19:47 #149993
Bloody hell mate good job you checked that's bad...... so the person who had it before you were just basically plugging in to the mains?? :S
- gusthegorilla
17 Aug 2015 19:55 #149998
by gusthegorilla
Yep...got it in one :S
You any idea where I can get a litre of Ford Focus "Electric Orange" mate? That's what it's called, honest :whistle:
17 Aug 2015 21:40 #150027
What do you need a litre of that for mate??sounds bright!! :woohoo:
Halfords mixes paint but I don't know in what volume
17 Aug 2015 21:43 #150028
221576530797 is this it?
