Damn hose
  • helijohn
01 Nov 2014 23:21 #128157 by helijohn
Damn hose was created by helijohn
Yes a damn hose. It is on a steel pipe and I can't get it off. Only room to get one hand in! It has welded itself to the pipe and I don't want to just cut it off cos then, as well as having to buy a new hose, I have to remove the hose from the other end which is even harder to get to.
What works on hose removal, obviously can't use a gas torch. Nightmare. :angry:
01 Nov 2014 23:42 #128162 by j999pre
Replied by j999pre on topic Damn hose
Pliers, grab and twist.
Grey pick up Jimny
  • NineCherries
02 Nov 2014 01:00 #128165 by NineCherries
Replied by NineCherries on topic Damn hose
is there room to tease it off with a screwdriver/ allen key? if not what about bending a welding rod or the like to work around it like a pick.
  • helijohn
02 Nov 2014 07:33 - 02 Nov 2014 07:47 #128168 by helijohn
Replied by helijohn on topic Damn hose
NineCherries wrote: is there room to tease it off with a screwdriver/ allen key? if not what about bending a welding rod or the like to work around it like a pick.
It might work if I can get a steel rod through the side but I'll have to see if there is room. I can barely get my hand in there. Normally I'd have inserted something like a rod or even a knife blade from the kitchen. If I hadn't been covered in underseal I'd have grabbed my camera for a piccy. I'll have it handy when I try again but the weather is awful today.
It is where the fuel filler pipe meets the fuel tank and there is a short (approx 8") of rubber hose joining the two. The tank is a few inches from the chassis and the pipe goes through a hole in the metalwork.
Like it but pliers are hard to hold plus it is a big hose so I would need giant pliers but you have made me think in terms of a chain wrench or strap; those will exert a crush on the pipe which may or may not be bad but might wreck the hose too.
Last edit: 02 Nov 2014 07:47 by helijohn.
02 Nov 2014 09:53 #128175 by j999pre
Doesn't look jimny?
I have some adjustable jaw type pliers/ grips. Light pressure on the rubber pipe and trying to turn the house back and forth usually breaks the stiction. That lot looks real rusty though?
Grey pick up Jimny
The following user(s) said Thank You: helijohn
  • helijohn
02 Nov 2014 11:10 #128178 by helijohn
It's a Shogun Pinin and that rust is only the start. :ohmy: :angry: I dunno if I have anything other than stilsons but I am thinking. Seeing if the weather improves and I'll have a go again.
Time to create page: 0.195 seconds
