Undoing crank pulley bolt?
- SOTA
- Visitor
facade wrote: Incidentally, my jimny had started to make A Noise when revved hard in first gear to pull away sharply, a sort of graunchy buzzy howl, just like a worn needle roller in the gearbox.
Mine started making a bit of a squealing sound like a loose belt, but belts were tight, as you say when pulling away hard, probably about a week ago. Engine management light came on yesterday morning and then the pulley went last night.
- Thank you received: 584
SOTA wrote: Fantastic how-to, thanks for the details.
Not sure when I'll get space to carry out repairs, I've refilled the water. With no water pump spinning will it be safe to start the engine just to manoeuvre the jimny into a place where I can work on it?
No longer than 30 seconds running time.
If it is filled with water yes. It will hardly get warm in 30 seconds.
Mine made A Dreadful Noise driving along then went quiet. The battery light was on, so I knew it had thrown a belt. Carried on about a mile 'till it was safe to stop, and the temp was at the top.
After I stopped, it blew coolant out of the overflow, and when cold had gone down to halfway between the marks.
- SOTA
- Visitor
By the time I had stopped, battery light was on and temp gauge hit the top, overflow bottle was knocked off it's bracket by the pressure and is now loose in the engine bay. I'll probably just zip tie that back in for the time being.
- Thank you received: 260
The new one looks like this (ooh shiny ).[/quote]
Brilliant. Shouldn't it be a sticky????
www.bigjimny.com/store/crankshaft-bolt-m13-series.html
- Thank you received: 333
I love this welding on nut trick so much I was clear out of nuts after dismantling my last rusty old SJ..Jezz wrote: If you end up going down the welder route, Get a nut large enough to fit over the bolt head and weld on, then you still have the new welded on nut to get a socket on. Similar to the photo.
