BigJimnyMeet 2024
Swivel leak but no play?
- wanderinstar
- Visitor
12 Mar 2012 23:23 #35404
by wanderinstar
Replied by wanderinstar on topic Re: Swivel leak but no play?
Whereabouts are you located. It doesn't say on your profile.
- Ads1987
- Visitor
13 Mar 2012 09:15 #35421
by Ads1987
Replied by Ads1987 on topic Re: Swivel leak but no play?
I'm in goudhurst in Kent, i've got an exploded diagram of the hub now and can see what you mean
I'm going to buy the hub tool anyway so I can have a decent look at the condition of the various bearings and seals etc properly. So i'll just replace the king pin bearings and shaft seal, but have a look at the wheel bearings and other seals.
Cheers!
Cheers!
- Ads1987
- Visitor
13 Mar 2012 09:17 #35422
by Ads1987
By the way, what oil type goes in the axles?
- Thank you received: 210
13 Mar 2012 10:33 - 13 Mar 2012 10:51 #35426
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: Swivel leak but no play?
M13AA manual
Type Quantity Specification
Engine Oil 4.0 litres10W - 30 (UK recommended)
Gearbox Oil API GL-4 1.1 litres 75W - 90
Transfer Box Oil API GL-4 0.8 litres 75W - 90
Differential Oil (Front)
API GL-5 1.1 litres 80W - 90
Differential Oil (Rear) API GL-5 1.3 litres 80W - 90
Coolant Capacity 4.5 litres
A/T Fluid/Power Steering Dextron IIE 1.1 litres
Brake Fluid DOT3
G13BB manual
Engine Oil 4.5 litres 10W - 30 (UK recommended)
Gearbox Oil API GL-4 1.3 litres 75W - 90
Transfer Box Oil API GL-4 0.9 litres 75W - 90
API GL-5 1.35 litres 80W - 90
Differential Oil (Rear) API GL-5 1.5 litres 80W - 90
Brake Fluid DOT3
G13BB manual
2002 JLX Soft Top
Last edit: 13 Mar 2012 10:51 by dirtydogz.
- Ads1987
- Visitor
13 Mar 2012 13:39 #35442
by Ads1987
Brilliant, thanks for the info, i've got the parts on order so will see how it all goes
Time to create page: 0.079 seconds
