BigJimnyMeet 2024
Swivel leak but no play?
- Ads1987
- Visitor
11 Mar 2012 18:45 #35303
by Ads1987
Swivel leak but no play? was created by Ads1987
Hi everyone,
I've just brought a w reg jimny to replace my defender, it's currently got big Kaiman malatesta mud tyres on that vibrate like hell. I've already found a replacement set but the front drivers swivel has ejected a load of grease and oil everywhere, Ive already read the how to guides etc and it's a very similar build to the defenders. My question is that I don't seem to have any play when jacking up and wobbling the wheels, so could the rough tyres have just vibrated the half shaft seal ? Or would you guys just suggest changing the king pin and wheel bearings a long with swivel seals etc?
Thanks!
Thanks!
- wanderinstar
- Visitor
11 Mar 2012 20:32 #35312
by wanderinstar
Replied by wanderinstar on topic Re: Swivel leak but no play?
Personally, if it was me, I would change the Kingpin bearings as the cost is minimal. You may as well do it as you will have taken the axle in bits anyway to change the drive-shaft seal.
- Ads1987
- Visitor
11 Mar 2012 21:43 #35323
by Ads1987
Replied by Ads1987 on topic Re: Swivel leak but no play?
do you think the main wheel bearings will need replacing? I suppose it just makes sense to do them anyway?
- wanderinstar
- Visitor
12 Mar 2012 09:11 #35340
by wanderinstar
- doncarlyon
- Visitor
12 Mar 2012 11:26 #35350
by doncarlyon
Replied by doncarlyon on topic Re: Swivel leak but no play?
If you only have vertical play, then chances are the wheel bearing will be ok.
- Ads1987
- Visitor
12 Mar 2012 16:28 #35363
by Ads1987
Can you change the king pin bearings easily without having the bearing removal tool then?
Cheers guys
Cheers guys
- wanderinstar
- Visitor
12 Mar 2012 17:51 #35371
by wanderinstar
Yes. I did it about 2 months ago.
- Ads1987
- Visitor
12 Mar 2012 19:34 #35380
by Ads1987
I assume you just unbolt the swivel seal and kingpin bearings and pull it off then?
- wanderinstar
- Visitor
12 Mar 2012 20:00 #35384
by wanderinstar
There is a "How to " guide here. Tells you everything you want to know.
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
- Ads1987
- Visitor
12 Mar 2012 20:17 #35391
by Ads1987
yeah i've read the guides, very useful but just wasn't sure how the hub would come off without the tool to remove the drive shaft/bearing etc
- wanderinstar
- Visitor
12 Mar 2012 20:40 #35396
by wanderinstar
Once you have removed the circlip and the square washer This will then allow you to take off the hub (once the kingpins have been removed). When you take the hub off the wheel bearing will come with it. Making it unnecessary to use the spacial tool to remove the wheel bearing.
Hope that I have made things clearer.
- Ads1987
- Visitor
12 Mar 2012 21:24 #35401
by Ads1987
bit hard to imagine as i havent seen it really! i'll probably just buy the tool anyway, it's probably going to be useful in the future by the sounds of it! cheers for the info
Time to create page: 0.112 seconds
