PDR
helijohn wrote: Now this is unbelievable. My dent is in the back door which should be a cinch to seal up.
wn.com/paintless_dent_repair_tricks__bicycle_pump
Worth a try??
We used to do this with motorcycle fuel tanks, it works well if the metal isn't creased.
- Thank you received: 260
Worth a try??
I may have a crease, will it still work?
This is genuine Duck tape in red but is it red Duck tape? lol
or this
- Thank you received: 585
If the metal has stretched it won't work, only if it has popped in like a dent in a ping-pong ball (you stick them in the kettle for a few seconds )
bound to be something on youtube...
facade wrote: bound to be something on youtube...
There is, been looking at all the 'miracle' dent repairs. I thought of inflating a hot water bottle. I can't get my hand there; it is right up by the bottom of the rear window.
I tried sealing off the door, what a joke!! I tried using my airline.
- Wiltec17
- Visitor
On the other hand he has done a couple that came out worse after he worked on it! So Its worth shopping about and going off a reliable recommendation.
Worth a try??
Good luck with that....
Made lots of alarming creaks, then went "pop" and the dent came out
Then I found that the tank which had originally been U shaped, was now \_/ shaped
So I had to get another from the breakers...........
Well I am considering using a hot water bottle cos I have seen how those can be blown up, by lung power alone, but OMG they are a fiver or more!!
