Norwegian Jimny G16b
- Thank you received: 10
G16B, Doug Thorley Header, Trail-Gear 6,5:1 Transfer, Front 28 Degree CV propShaft, Redacted crawler box kit, Zanfi 2" springs, Zanfi 10° + 10mm Front Radius arm, Caster Correction Bushes rear, Adjustable Panhard, Bilstein 5100 Shocks, Dotz dakar 15x7, goodyear duratrac 235x75x15, warn M6000
- Thank you received: 216
But why put the Jimny Camshaft in the baleno head?
+3" Trail Master. Fox 8.0" R/R shocks. ORA HD winchbumper. Warn M8274 Ox-motor + Hellfire gears, Delta-Tek mainshaft and freespool, overvolted. 33/9.5 R16 Silverstone Extreme. 5.14:1 ratio SJ transferbox in RW cradle. OMP rollcage.
Sent from my Nexus 5 using Tapatalk
Just read something about the engine wont do as many rpm with the Jimny cam in. Don't know if it's because of the cam sensor pickup ring, with can be swapped rather easy.
and its revs good from 1000 rpm to 6000 rpm
Wonder if that stanless steel header makes any difference.
- Thank you received: 244
I've just found what I was looking for, it was where I left it ...
TomDK wrote: Just read something about the engine wont do as many rpm with the Jimny cam in. Don't know if it's because of the cam sensor pickup ring, with can be swapped rather easy.
Its because its got less duration and a little less lift.
- the_goshawker
- Thank you received: 72
2003 Silver Suzuki Jimny Falconer Edition...
OZ Alloys...
215 75 15 Toyo open Country...
SolarPlexus Rear Tints...
K&N Panel Filter...
Rear Upper Spoiler..
www.jimny.se/index.php/forum?viewic&cati...d=56189&limitstart=0
Have test driven it for 3 weeks now and the difference is amazing!!
mlines : starting up video coming soon
Thanks
