Re:JB74 OBD2 connection
21 Dec 2020 13:24 #231083 by Bill Portland
I see that the latest update of the SZ viewer app now has a TPMS tab. I must plug it in and see what it does.
21 Dec 2020 16:13 #231084 by mlines
Replied by mlines on topic JB74 OBD2 connection
Looking at the Circuit diagrams, for the UK it appears to be
Pin 1 - (Grey) - +12Volts
Pin 3 - (White) - CAN
Pin 11 - (Blue) - CAN
Pin 12 - (Black) - Ground
Pin 13 - (Black) - Ground
Now those of you familiar with OBD2 wiring will be intrigued by the numbers as they should be
Pin 16 - 12v
Pin 6 - CAN
Pin 14 - CAN
Pin 4 - Ground
Pin 5 - Ground.
However if you count the pins backwards then the numbers match so I think either Suzuki or the OBD2 specification looks at the reverse of the connector.
26 Dec 2020 17:06 #231208 by DrRobin
Replied by DrRobin on topic JB74 OBD2 connection
This is the OBD2 connector on my Gen3 from 2011, no CAN bus on this variant.
The dongles/obd reader I have has the pin numbers marked on treating face, but they don’t seem to be on the socket (attached to the car) so PIN numbers must be from the plug end.
26 Dec 2020 20:18 #231216 by mlines
Replied by mlines on topic Re:JB74 OBD2 connection
By coincidence I was playing with code reading today
The following user(s) said Thank You: Bill Portland
  • Twisticles
21 Jan 2021 05:02 #232021 by Twisticles
Replied by Twisticles on topic JB74 OBD2 connection
Did you ever figure this out?
I'm interested in the Autool or similar.
HK version Jimny here!
  • stuart
02 Feb 2021 01:46 #232416 by stuart
Replied by stuart on topic JB74 OBD2 connection
Unfortunatly not, I'm still very interested in finding a solution though!
Time to create page: 1.914 seconds
