BigJimnyMeet 2024
Yokohama Geolandar
25 Jan 2024 18:08 #253751
by Motacilla
Replied by Motacilla on topic Yokohama Geolandar
Roger, did you mean 195/80 for the G015, i.e. factory Gen4 Jimny size?
- Thank you received: 479
25 Jan 2024 18:48 #253754
Replied by Soeley on topic Yokohama Geolandar
I have the 195/80/15 Geolanders on my Gen4. I wanted to keep the original size.
Perhaps they have stopped doing that size now?
- Thank you received: 653
25 Jan 2024 19:22 #253756
Replied by jackonlyjack on topic Yokohama Geolandar
215 75 15's is the ideal swap for 195 80 15
- rogerzilla
- Visitor
25 Jan 2024 21:16 #253759
by rogerzilla
Replied by rogerzilla on topic Yokohama Geolandar
I did mean 195/80 but I can't paste a link - the forum software and my phone don't get on!
- Thank you received: 2
26 Jan 2024 00:06 - 26 Jan 2024 00:12 #253763
by AJ
Replied by AJ on topic Yokohama Geolandar
Hi everyone
I seem to have caused some confusion, and indeed did when I ordered from my local supplier who I have used for a great many years. The link I posted was the one that came up for a 2019 Jimny and I assumed that it was correct, other sites also came up with the 205 size so that i what t I ordered. I couldn't find the 195's anywhere when I put Jimny mor my reg into the online sites. Took my Jimny in today to have them fitted but after half an hour received call to say they are not the same as the tyres fitted to my car. It seems that both the 195 and 205 are listed as being correct for the Jimny, the 205 being the more common tyre, the 195 is a rarer beast but the one I really wanted . I am lucky in having a good local dealer (Autotyres Shrewsbury) who spotted the difference and gave me the chance to change them for the 195 which are now on order. They are about a fiver more each tyre but I prefer a narrower tyre, I find it gets me to where I want to go with less drama.
Adrian
Adrian
Last edit: 26 Jan 2024 00:12 by AJ. Reason: correct errors as usual!
26 Jan 2024 09:38 #253770
Someone will correct me if I'm wrong, but I think the 205s were the std size for the Gen3 tyres.
- Thank you received: 372
26 Jan 2024 10:30 #253776
Replied by DrRobin on topic Yokohama Geolandar
205/70R15 was standard for Gen3.
The largest size without a lift/bumper trim you can go to is 215/75R15. They are about 4% bigger so your speedo unreads by 4%. Most speedos over-read and mine over-read by around 4-5% so now it is spot on.
I noticed a small difference in ability to pull top gear on hills, but that might be more to do with the increased weight of the 215/75 tyre.
Robin
Robin
26 Jan 2024 23:39 #253803
by AJ
Geolanders fitted today, great service from my supplier. First impressions are they are quiet, better than the factory fitted Bridgestones. The car feels different too, its like the tyres are sticky and holding it to the road, weird but true. Did a short 30 mile run on roads that included dual carridgeway, A roads, B roads and single track lanes with grass in the middle, car felt good at all speeds and very stable, MPG was about the same as with the old tyres at 48 mpg on the dash readout when I arrived home, wasn't holding back either. Ride may be a tad harder but still very comfortable. Overall I'm very impressed, they exceed my expectations in all respects.
Thanks to everyone who contributed to this thread.
Adrian
Adrian
- Thank you received: 1761
27 Jan 2024 05:33 #253805
Replied by Lambert on topic Yokohama Geolandar
Not geolandars but my ats also feel way stickier than the Bridgestone it's not just you.
The following user(s) said Thank You: AJ
27 Jan 2024 08:57 #253809
AJ, you say the ride feels harder, have you checked they haven't over inflated the tyres? should still be at the 26psi all round, 29psi for the rear id loaded up.
27 Jan 2024 10:11 #253810
by AJ
Thanks Lambert, was thinking I was imagining things but it is true, they make the Jimny feel like it's stuck to the road.
27 Jan 2024 10:39 #253813
by AJ
Hi Soeley, yes checked the pressures before I went for the first drive, all spot on 26psi, they also used a torque wrench for the wheelnuts and got that right too. The harder ride was very slight and possibly just the different feeling the Geolandars have imparted on the cars handling, also because they are so new I'm pretty sure the ride will settle down once they have 'bedded' in so to speak. It may be it's just me picking up every tiny difference in the cars behavior since the new tyres were fitted, when something changes from what I'm used to my imagination can also play a part in things. I have to say that overall I'm extremely pleased with the Geolandars, they seem to be a great improvement over the original Bridgstones.
Adrian
Adrian
