Jimny GEN4 RECALL - UK
11 Jun 2021 11:39 - 11 Jun 2021 11:55 #235715
Jimny GEN4 RECALL - UK was created by mlines
Two RECALL notices have been issued for the GEN4 Jimny in the UK
1. Door harness replacement 4W-TS-0621-006- both the passenger and driver door harnesses need replacing due to the likelyhood of wear damage affecting airbag operation. VIN Numbers JSAGJB74V00100111 - JSAGJB74V00140475 ONLY
2. Fuel Pump replacement 4W-TS-0621-005- Fuel pump impeller improperly made and it may swell impacting pump operation. Engine may stall, run improperly or stop altogether. VIN Numbers - JSAGJB74V00100111 - JSAGJB74V00108164 ONLY
What do you have to do?. If your car is properly registered then Suzuki will contact you based on DVLA data, otherwise contact your dealer to confirm yours is with the range specified and is eligible for the recall
Last edit: 11 Jun 2021 11:55 by mlines.
11 Jun 2021 11:42 - 11 Jun 2021 11:54 #235717
Replied by Soeley on topic Jimny GEN4 RECALL - UK
Looks like I'll be getting a call from Appleyards then.
Last edit: 11 Jun 2021 11:54 by mlines.
11 Jun 2021 11:51 - 11 Jun 2021 11:54 #235719
Replied by mlines on topic Jimny GEN4 RECALL - UK
And James, if you are reading this, Gerald requires the first recall but not the second, so new door harnesses needed.
11 Jun 2021 11:57 #235720
by 300bhpton
Replied by 300bhpton on topic Jimny GEN4 RECALL - UK
Thanks for the heads up, looks like mine will need the door harness too.
Are these the only recalls for the UK? Someone posted on another site about the windscreen leaking, but hadn't heard anything from Suzuki.
11 Jun 2021 12:01 #235721
Yes, these are the only recalls in the UK.
Australia has a recall on the glass falling out due to the incorrect bonding being applied, but that was only 5 vehicles and they were handling it direct with the owners apparently. I have not heard of this affecting other countries.
The following user(s) said Thank You: 300bhpton
11 Jun 2021 12:09 #235722
by Gadget
Replied by Gadget on topic Jimny GEN4 RECALL - UK
Bum. Mine needs both.
Thanks for the heads-up Martin.
Time to create page: 2.295 seconds
