BigJimnyMeet 2024
Re:2019 Jimny Australian special upgrade, or not?
- cyberdriver
- Visitor
19 Jan 2019 12:46 #201133
by cyberdriver
2019 Jimny Australian special upgrade, or not? was created by cyberdriver
G'day!
My local dealer is fitting its only demo Jimny (an auto) with a 50mm lift, wider (6") steel rims and 235/75R15 AT tyres before the official launch in Australia because they reckon this will be a popular (and legal) combo - and are offering the same to customers of either manual/auto. Apparently it's recommended/endorsed by Suzuki Aus, and no other mods are required (e.g. trimming wheel arches, lengthening cables, reducing gear ratios).
Is this the sweet spot for a mild upgrade? I can obviously test drive it, but not off-road. Before learning of this option I was thinking of just 215/75R15 ATs on the OEM alloy rims. I'll be doing some beach driving and sandy tracks/dunes but nothing too extreme - in a manual.
Where do you think I should start?
Cheers.
Cheers.
- Thank you received: 225
20 Jan 2019 01:22 #201199
by zukebob
Replied by zukebob on topic 2019 Jimny Australian special upgrade, or not?
Personally, I would start with your original idea. While you can drive on 235/75r15 without gearing modification, it is about the limit and you would notice a change.
I think after driving on 215/75r15 tires, you can make a more reasonable decision if larger tires would be better at meeting your needs (not very likely on the beach).
The following user(s) said Thank You: cyberdriver
- cyberdriver
- Visitor
20 Jan 2019 23:07 #201276
by cyberdriver
Replied by cyberdriver on topic 2019 Jimny Australian special upgrade, or not?
Hi George, yes - hot here too! I would have liked yellow with white roof, or full ivory, but the black roof (or jungle green roof) is a deal breaker. It seems a bit silly to paint/wrap the roof- so the white one is a no-brainer for me. Probably a longer wait-list though.
Thanks, Zukebob. I suspect they'll get a lot of takers for the upgrade based on its looks, rather than function. The dealer does pretty well out of it too ($$) so it's win-win! Will do some reading about equipment for beach driving
- Thank you received: 95
20 Jan 2019 23:45 #201279
by Bob1050
Replied by Bob1050 on topic 2019 Jimny Australian special upgrade, or not?
Seems a really bizarre decision not to offer a white roof option - in a country renowned for baking hot sunshine.
Maybe the marketing team made the decision on a cold day in a cold country or they feel that a white roof on a 4X4 is the signature of competitor brand?
Personally I'd jump at the opportunity of a white roof.
- Thank you received: 1761
21 Jan 2019 07:30 #201291
Replied by Lambert on topic 2019 Jimny Australian special upgrade, or not?
Isn't fitting larger diameter tyres going to be unhelpful for sand driving, it's not like the 1.5 is some kind of torque monster and sand is notoriously hard on transmissions?
- Thank you received: 333
21 Jan 2019 08:29 #201292
Replied by yakuza on topic 2019 Jimny Australian special upgrade, or not?
I had 235's on my 1.3 80hp jimny, and even 235 on my 1.3 63hp SJ.
Clutch life is shorter and it was no racer in any way but still fun.
I even had 31" on my 63hp SJ413 but then with the lower rocklobster transfer gearing.
I would change the gears (again) for 235 before the engine..
- cyberdriver
- Visitor
21 Jan 2019 21:10 #201387
by cyberdriver
You might be right, :Lambert, but I was thinking larger diameter for axle clearance and wider for float. Would you leave it stock for beach/dune/sand tracks?
22 Jan 2019 02:49 #201393
by zukebob
I mostly avoided sand but did do some beach driving and a bit of desert driving early on. Initially I had the stock tires which were equivalent to 225/75r15. Later I went with 32 X 11.5. The stock tires worked better for me in the sand.
The vehicle I had at the time was significantly heavier than the Jimny so I would defer to anyone that is using a Jimny for beach or dunes. If you don't receive a Jimny specific reply, it would probably still be good guidance.
22 Jan 2019 05:13 #201395
In Yorkshire there are no obvious places to sand drive so my knowledge is second hand but as I understand it sand really needs momentum as much as anything to keep you on the top and if you do sink in you need very low wheel speed to creep forward. Both these require torque which is a limited resource in a Jimny even the 1.5. I get what you mean about better float and clearance but more float means more drag needs more torque and more diameter means higher gearing needs more torque. Personally I'd be after a set of proper all terrain tyres in stock size and preserve what torque there is.
22 Jan 2019 05:22 - 22 Jan 2019 14:16 #201396
Also have a look at Ronny Dahl on YouTube he is based in West Aus and seems quite knowledgeable about sand driving, quite a big back catalogue though and I haven't seen a comparison of his for this specific case but there's bound to be some good information there.
Last edit: 22 Jan 2019 14:16 by Lambert.
- mikeyw85
- Visitor
22 Jan 2019 10:08 #201400
by mikeyw85
Replied by mikeyw85 on topic 2019 Jimny Australian special upgrade, or not?
Does it require the lift to fit those tyres?
22 Jan 2019 10:33 - 22 Jan 2019 10:34 #201403
With the 235 its a 6pc increase in height or approximately 50mm ish plus an extra 40mm width. I'd be surprised if they didn't catch somewhere on full lock full compression?
Last edit: 22 Jan 2019 10:34 by Lambert.
