Rear hazard/fog lights
- Thank you received: 260
Busta wrote: I hope you use your fog lights wisely John!
Aha.
I use it as I would have with the single one.
I too hate light pollution, particularly the Volvos running around with bright LEDs on all day.
- Thank you received: 142
Busta wrote: I hope you use your fog lights wisely John! A pet hate of mine is people that use them in conditions other than thick fog (I mean sub 50m viibility) or leave them switched on for a couple of days after the fog has cleared.
They are easily confused for brake lights (especially when there are 2 of them ) and I find they are very bright and irritating when you are in heavy traffic. People that use them in heavy rain they are a total nightmare!
Agreed!! As an ex hgv driver I think they should have a sensor on them so that when they sense headlights behind they switch off!!
The UK public seem incapable of using them correctly.
I find that modern cars with LED lights are bright enough already.
It was a pet hate of mine as I was a night driver and even emergency services lights are too bright at night so much so that I've had to virtually stop to get past multiple emergency vehicles as they blinded you making the situation worse!!
In dense fog though I want really bright lights! Nothing worse than having a heavy plough into you.
An easy test is how far ahead can you see? If it's 1/2 a mile or more you don't need them on. If you are in traffic and can see lights behind you,you don't need them on.
Have you thought about how much extra light you are now putting out ?
I don't think it's too much of a problem on the Jimny but a lot of cars have their indicators/brake lights close to the rear fog lights and it masks the brake lights!
In all my 40 years of driving I think I've only had them on a handful of times.
- ands
- Visitor
What we have for the rear fog should be in the bumper. The one in the door pillar is the tail lights. But will check it non the less. Thankshelijohn wrote:
ands wrote: would like to ask the comments of the experts
the Jimny we got here in the Philippines does not come with a rear fog light. the wiring harness is there. would like to know if somebody can give me part numbers for the 1. Rear fog lamp lens (ours should be in the bumper) 2. rear fog lamp switch 3. rear fog lamp socket
i think this photo is the rear fog lamp lens with sockets?
Have you looked in the main lens unit - on the door pillars - to see if there is a blank or available light bulb socket?
Sent from my GT-I9300 using Tapatalk 2
gilburton wrote: Have you thought about how much extra light you are now putting out ?
I've had lots of motors with two rear fog lights. It's a bit motorbike looking when there is only one even if on the offside.
- jerry
- Visitor
jerry wrote: Most makers fit one fog light because having two often confuses traffic behind you into thinking your braking , I'll be keeping just the one .....
I think they do it for economy!! Can't see how two lights being on permanently would be like braking and the extra light could be a lifesaver in thick fog, brakes or otherwise.
Often the position of the fog light on one side is mocked by the reversing light on the other.
I genuinely think fog lights (and peoples failure to use them correctly) causes more problems than they prevent. I probably use mine twice a year, and switch them off as soon as a car approaching from behind knows I'm there. Why some people drive around with them on in perfect visibility or heavy rain is a mystery to me.
- Dirtbird
- Visitor
- Thank you received: 1763
