Forum
Suzuki Jimny
Jimny Chat
Rear hazard/fog lights
BigJimnyMeet 2024
Thank you received: 650
Thank you received: 82
25 Jan 2019 20:21 - 25 Jan 2019 20:25 #201703
by Dirtbird
Jackonlyjack that answered a load of questions . I went with the ring ones as well and was in the shed tonight wondering where to locate them and how to wire them in.
I am thinking of taking the reverse light into the cab and hang them under the brake light on the rear door window. So when I engage revers my reverse light comes on but I also want to have a switch that turns on the reverse light with out having to engage reverse. ANY SUGGESTIONS GREATLY ACCEPTED .
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Last edit: 25 Jan 2019 20:25 by
Dirtbird.
26 Jan 2019 11:49 #201737
I run these from a separate switch
Not good for reversing because of glare/reflection off window
You can over come this by making a surround that fits flush to the glass
I only use them as work lights as the ring reverse light on back door works from gear box
The following user(s) said Thank You:
Dirtbird
29 Jan 2019 09:21 - 29 Jan 2019 09:25 #202005
by Dirtbird
jackonlyjack wrote: I run these from a separate switch
Not good for reversing because of glare/reflection off the window
You can overcome this by making a surround that fits flush to the glass
I only use them as work lights as the ring reverse light on the back door works from gear box
Ok here is how it went. Took the power from the driver side reverse lamp and extended it into the door and up and out the top of the back door at the brake light. Made a little bracket to hold the lamp against the door facing out. Spent a bit of time taking the reverse switch out and checking, turns out switch is working. Then look for my rubber neck attachment for inspecting the fuse box under the steering wheel. 4TH fuse down on left-hand side 10 A blown, replaced it and reverse lights are now working.
Light reflectiong into rear but not glaring . in effect an additional interior light .
I know you are saying why inside, just over the years I've damaged and destroyed so many spots, Im, just going to mind em now.
Last edit: 29 Jan 2019 09:25 by
Dirtbird.
Forum
Suzuki Jimny
Jimny Chat
Time to create page: 0.126 seconds
