BigJimnyMeet 2024
Is serious rust a problem with early models yet ?
- doncarlyon
- Visitor
19 Oct 2011 14:22 #24030
by doncarlyon
Replied by doncarlyon on topic Re: Is serious rust a problem with early models yet ?
Errrm oh dear!
- Gromit
- Visitor
20 Oct 2011 08:33 - 20 Oct 2011 08:35 #24085
by Gromit
Replied by Gromit on topic Re: Is serious rust a problem with early models yet ?
My old red S reg was a rot box in the boot but the 51 plate seems to be ok. It has a 2" bodylift which is handy as it's easier to get to the underside of the bodywork & the top of the fuel tank with Waxoyl.
Last edit: 20 Oct 2011 08:35 by Gromit.
- doncarlyon
- Visitor
20 Oct 2011 08:59 #24087
by doncarlyon
Mines a 2001 Y reg and i have a few holes in the rear floor. Will be getting patched up for the MOT and some form of waxoyl / protection aswell.
24 Oct 2011 17:17 #24345
by mcjimny
Replied by mcjimny on topic Re: Is serious rust a problem with early models yet ?
As a heads up to others, i had my seats down the other day and noticed a scab of rust just infront of each seatbelt bolt under the rear seats. Its just surface at the moment and about 2" but i'll be treating it and painting asap!.
- adamatdraycott
- Visitor
24 Oct 2011 17:38 #24348
by adamatdraycott
Replied by adamatdraycott on topic Re: Is serious rust a problem with early models yet ?
I have the same on an 04... although a much smaller patch... maybe the size of a 10p
I think this maybe caused by condensation running down the back of the trim... as one day i noticed a lot of condensation, and a while later the floor felt damp. Is this feasible?
I treated it a couple of months ago, no sign of it returning
24 Oct 2011 18:20 #24364
by mcjimny
Could easily be the cause, i'll be having a good look underneath too as its a future mot failure if left untreated as its near the seatbelt mounts
- doncarlyon
- Visitor
24 Oct 2011 18:24 #24365
by doncarlyon
I will get some pics of mine soon.
Do breakers like cam suzuki sell the floorpan do you know?
- Chilgrove
- Visitor
24 Oct 2011 19:10 #24378
by Chilgrove
Replied by Chilgrove on topic Re: Is serious rust a problem with early models yet ?
I cannot see any reason for the boot floor in particular to rust. The area around the jack storage point seems especially vulnerable and I assume the rust is from the outside in. I noticed on mine about 3 convex dents but how on earth could that have happened in the first place? I don't think mine has ever been off road and even if it had it is hard to see why that particular area suffers.
Howard.
Howard.
24 Oct 2011 19:27 #24380
Replied by mlines on topic Re: Is serious rust a problem with early models yet ?
The boot floor tends to rust in soft tops as leaking water collects at the lowest point. Also, being Spanish, they may have boot been galvanized .
Sent from my HTC Desire using Tapatalk
- p1ngu32
- Visitor
24 Oct 2011 19:30 #24382
by p1ngu32
Replied by p1ngu32 on topic Re: Is serious rust a problem with early models yet ?
Ive just finished welding up the holes in my floor today, it seems that the rust appears any where where there is a bracket or streghthening bar/crossmember under the floor, water probably gets trapped in there and rusts the floor from the bottom up. might be an idea to blast some waxoyl or similar stuff under there before it gets a hold.
Some pictures
Before i started with my rust poking screwdriver
After a bit of screwdriverage
I then cut out all the rusty bits but i didnt get any pictures of this i was busy and forgot.
Welded in some nice thick gauge steel thats not going to rust any time soon
Painted up, you can see the other problem areas around the seat belts, i cut out the worst of these and overlapped about 5mm
And finally a hole in the driver side sill i repaired last year.
Some pictures
- X-Eng Simon
- Visitor
24 Oct 2011 19:56 #24384
by X-Eng Simon
Replied by X-Eng Simon on topic Re: Is serious rust a problem with early models yet ?
Mine seems pretty good. Quite a lot of the panel work is zinc plated (and painted) though there are some exceptions such as the outer skin behind the rear wheels where it was originally covered with plastic trim.
The chassis is perfect as well as the floor and sills. It's a 1999 Spanish built soft top by the way.
This evening I took off the soft top above the front seats and found that the frame is rotten as a carrot and turned to dust in my hands. It wasn't a problem as I was going to make a rigid roof anyway.
Si
Si
- VAXXi
- Visitor
14 Nov 2011 14:07 #25746
by VAXXi
Replied by VAXXi on topic Re: Is serious rust a problem with early models yet ?
Time to create page: 0.143 seconds
