BigJimnyMeet 2024
New Member and Advice Needed...
- Pete E
- Visitor
05 Feb 2011 00:02 - 05 Feb 2011 00:02 #10978
by Pete E
Replied by Pete E on topic Re: New Member and Advice Needed...
Thanks again for all the advice folks...
A couple of other questions: if I go from from 205/70/R15 to 215/75/R15's, will it effect the gearing much? I do some fairly long trips in my Jimny and use 5th gear a lot and don't want to do anything that will bugger that up too much...
Also can anybody recomend a good AT type tyre in 215/75, plus the best place to source them?
Thanks again,
Peter
Thanks again,
Peter
Last edit: 05 Feb 2011 00:02 by Pete E.
- biggaz
- Visitor
05 Feb 2011 05:34 #10981
by biggaz
Replied by biggaz on topic Re: New Member and Advice Needed...
Ive got 215 75 but in a mud pattern and the gearing is affected but i can live with it fine, its not that bad. Think its about the biggest you should go if using a lot.
I find camskill great for tyres.
- Pete E
- Visitor
05 Feb 2011 11:27 - 05 Feb 2011 11:33 #10991
by Pete E
I was wondering if i could sneak in a set of 225 75 R15 Goodrich BFG AT's such that would fit ok without too adverse an effect on the gearing but I suspect the 215's sound to be a safer option...
I was also wondering about the Goodrich MKTM2's MUD' s but I'm again worried if they will too noisy on road??
Last edit: 05 Feb 2011 11:33 by Pete E.
- biggaz
- Visitor
05 Feb 2011 11:35 #10992
by biggaz
You could probably get away with that i would have thought. They dont list that size on camskill in the bfg's though so not sure if they do them.
General grabber at2's are in that size, will you be doing any decent offroading? would you not prefer some mud tyres which are well behaved on road? Just after a recent trip out i seen how the
mud tyres and the all terrains were completlely different when it got a bit sloppy. SO pleased i went for muds now over A/T's.
- Pete E
- Visitor
05 Feb 2011 16:49 #11019
by Pete E
I'm in North Wales, (near Chirk) so there are quite a few greenlanes to go at, some easy some not so easy...Not really looking at doing "pay and play", mud pits or trials/competions..
I've had AT in the past on a Trooper and they were *ok* but as you say not brilliant..A friend had some serious Muds (not sure what brand) on a Jeep and they were were noisy as hell, so it put me off them for a daily driver..
Do you find the Goodrich Muds acceptable on the road? Any down sides to them?
- biggaz
- Visitor
05 Feb 2011 16:55 #11021
by biggaz
Yeh mate, the downside is the price......
There great on road, little noise as expected but far better than i thought! another good mud tyre for the road is the kumho kl71, bit cheaper too!
I'd definatly buy muds again, probably the bfg's again aswell because they are quite quiet and well behaved.
- Keefe
- Visitor
05 Feb 2011 17:27 #11024
by Keefe
Replied by Keefe on topic Re: New Member and Advice Needed...
I found the only problem with the KL71's was the soft side walls.
I used to worry on 'sharp' ground such as rutted slate.
A friend of mine had a brand new one ruined due to a large piece of slate piercing the sidewall.
They are nice though.
K
Just to mention, mine were fitted on a much bigger/heavier vehicle than the Jimny
K
- Pete E
- Visitor
05 Feb 2011 18:15 #11031
by Pete E
In one of the tyre places mentioned earlier in the thread the Goodrich Muds are £92 which is about £5 a piece cheaper than the AT's...I'll get a print off of the price list and see if my local tyre place will match them or at least come close..
- biggaz
- Visitor
05 Feb 2011 19:16 - 05 Feb 2011 19:18 #11041
by biggaz
i got mine from camskill if thats where you mean, good service from them. Remeber the tyre fitters are gonna put the fitting charge on aswell but you need to pay that anyway..
Are you going for 215/75? they dont rub on standard susp but look much better on the steel modulars, only 120 quid a set with bit wider rim and lower offset for stability..
standard height on bfg with modulars, you can get them from the saved insurance money hehe!
Attachment IMAG0111_2011-02-05.jpg not found
Attachment IMAG0109.jpg not found
Last edit: 05 Feb 2011 19:18 by biggaz.
- Pete E
- Visitor
05 Feb 2011 19:30 #11046
by Pete E
I have to say they do look good in that pic!
Is that Jimny otherwise standard, ie no lifts?
The modulars sound a good idea...would it be better than keeping my standard Jimny steel rims and adding spaces?
- biggaz
- Visitor
05 Feb 2011 19:52 #11049
by biggaz
Id ALWAYS say its better than spacers, there 15x7 with a much lower offset so look great and give the same extra width as spacers but with 4 new shiny rims!
Dave T was gonna buy some spacers but went for the rims instead and i think hes chuffed with them.
Yes in that pic, standard apart from wheel/tyre, look in my "my jimny" thread for the full details.
with 3" LIFT
with 3" LIFT
- Pete E
- Visitor
05 Feb 2011 20:15 #11054
by Pete E
Thanks again for the help, this is really helping me get a sensible plan of action for a build..
Looks like if I go for the 215/75's Muds and modulars as the first serious upgrade, I can then add a 2" suspension lift at a later date as funds permit.
Any recommend sources for the modulars? Any where likely to a deal on a set of wheels and tyres together?
Regards,
Peter
Regards,
Peter
