1.6 engine conversion without using adapter kit
- gus2000
24 Aug 2015 19:31 - 08 Mar 2019 13:46 #150527
by gus2000
1.6 engine conversion without using adapter kit was created by gus2000
Hello.
I approached some modifications as proposed in
www.rumbozeroexpediciones.com/app/.../TT-102+SUZUKI+1600.pdf
G16b Engine from Suzuki baleno 2001.
Without using engine-gearbox adapter kit.
Aligner is constructed to ensure proper alignment engine box
Box holes are enlarged to accommodate the knock pin and allow the motor screw
At the bottom we drilled the two parts (engine and gearbox) simultaneously to insert a "pin" which allow the correct centering of the two parts
Lower coupling piece
Jimny oil strainer with 1.6 connection welded
Flywheel of jimny in 1,6 engine
Jimny phonic wheel in the 1.6 engine. You must be careful to place it in the correct angle
Test 1,6 injectors.
Right engine modifications
Left engine modifications
Assembly engine gearbox set
Motor circuit filled with oil, using a soda bottle pressurized with air. The connection is made in the oil pressure switch.
Relocation exhaust pipe
Close-fitting
Prolongation of the lower support from the exhaust
Ignition timing is correct.
Ready to use
Thank you very much to those who helped me in the work
Best regards. Gustavo
Test 1,6 injectors.
Close-fitting
Ready to use
Last edit: 08 Mar 2019 13:46 by mlines. Reason: Corrected picture links
- craigy123
25 Aug 2015 08:10 #150573
by craigy123
Replied by craigy123 on topic 1.6 engine conversion without using adapter kit
Very impressive engineering.
- GraphicX
29 Aug 2015 09:46 #150902
by GraphicX
Replied by GraphicX on topic 1.6 engine conversion without using adapter kit
fantastic work !
- fc.tanou
25 Jan 2016 10:25 #161106
by fc.tanou
Replied by fc.tanou on topic 1.6 engine conversion without using adapter kit
My friend can you tell me what is the correct position of the ring behind of the camshaft.the camshaft on the front of engine is it in timing?
- gus2000
26 Jan 2016 15:25 #161226
by gus2000
Hello,
For install the phonic wheel
1) put the engine in "timming belt instalation" (crankshaft and camshaft) ..
2) insert the phonic wheel (whith the front face properly) as the figure
gustavo
Replied by gus2000 on topic 1.6 engine conversion without using adapter kit
fc.tanou wrote: My friend can you tell me what is the correct position of the ring behind of the camshaft.the camshaft on the front of engine is it in timing?
Hello,
gustavo
- Cider
30 Jan 2016 16:27 #161506
by Cider
Replied by Cider on topic 1.6 engine conversion without using adapter kit
Wow
A great write up.........
