Jimny from Dorset Now with Carputer
- srcars
25 Feb 2011 19:04 #12174
by srcars
Replied by srcars on topic Re: Jimny from Dorset soon to be 2
- srcars
07 May 2011 07:57 #15997
by srcars
Replied by srcars on topic Re: Jimny from Dorset Now with Carputer
Had most of the parts for an in car PC knocing about for ages but never got round to fitting them in anything untill now. Its very similar in principal to Viciouspenguin's set up but in theory the hole thing is operated via a touch screen instead of a keyboard.
After a chat with my MOT man I removed my air bags (if you dissconnect the airbag brain under the gearbox console you dont get a dash light)
This left me a nice space to play with
After a bit of cutting I managed to fit a 8" touch screen which had been left in its box for a good couple of years :blush:
Its not the best job but I managed to fill the gaps and still manage to get the cover on which clips on and off to hide the screen when not in use.
The on/off button
And a couple of USB ports for memory sticks ect.
And the PC itself. It cant be seen when the seat is in its normal position
Just messing with the software now but it is running my on road sat nav and memory map for off road trips. Its also plays mp3s stored on the pc even when in sat nav mode with the sound playing through the uprated stereo/speakers fitted. This is all operated via a front end program with nice big buttons to make operating the system nice and easy. Soon to come are video cameras front and rear which will record to the hard drive. Permanent Internet access via my mobile and lots lots more.
The on/off button
- Keefe
07 May 2011 08:19 #15999
by Keefe
Replied by Keefe on topic Re: Jimny from Dorset Now with Carputer
Wow! I like it, keep the updates coming.
Obviously you have good door seals?
Or you don't do deep water.
You are giving me ideas, I have a laptop in the shed that could be 'reclaimed' for a faff with. A net book might be a better option though?
Like it.
K
Like it.
K
- viciouspenguin
07 May 2011 20:35 - 07 May 2011 20:37 #16024
by viciouspenguin
Replied by viciouspenguin on topic Re: Jimny from Dorset Now with Carputer
nice setup, bit like mine
i suggest you get a keyboard of some sort. the first pc i put into my SJ didnt have one and it drove me nuts.
www.sj410.co.uk/charger/garage/090531.html
what spec if the pc, how much did it cost if i can ask. what software do you run?
Attachment 23.jpg not found
Attachment netbook.jpg not found
Last edit: 07 May 2011 20:37 by viciouspenguin.
- Asbojimny
08 May 2011 15:14 #16037
by Asbojimny
Replied by Asbojimny on topic Re: Jimny from Dorset Now with Carputer
Nice set up/install. I was thinkin of gettin somethin to run MM. Would love a touch screen. Those 7" notebook things look are a good idea. I have a Garmin E trex i could use as a GPS unit,but have also noticed the dongle type on eblag.
- srcars
08 May 2011 15:49 #16042
by srcars
keefe, I mainly do lanes and have never had water in the car yet but I will be a lot more vigilant untill I know the door seals are OK, I read somewhere that a Jimny will float when water gets to the top of the headlights so they must be pretty watertight :laugh: Time will tell....
I did have it running on a net book while I was testing things out and fitting the screen and it worked great so worth trying, the only reason I went with the pc was I had most of the parts and couldnt be bothered to keep taking in in and out :S
VisciousPenguin. I have had a good look round you website, Lots of interesting stuff on there.
I havent missed the keyboard yet and have only used the on screen keyboard once so far but I have seen a wireless one the size of a remote I could leave in the glovebox which I may get sometime.
Apart from the screen and the power supply its made up from 2nd hand parts and spares I already had and owes me a tad under £200, its not going to be the fastest thing in the world but then it doesnt need to be.
The main components are an Intel mini itx motherboard D945GCLF with a Atom processor 230. 1gb of ram and a 120GB hard drive. Its powered by a M2-Atx Intelligent power supply.
At the moment I have installed Windows XP and a program called 'Media Engine' which is a bit of software that allows access to any programs you use via nice big buttons and easy to read menus designed for in car use. I am using Memory Map for off road mapping and a program called Sygic Drive for on road sat nav. I can access any music stored on the hard drive while these are running and the sound plays through the uprated car stereo and speakers. I have lots of plans including internet access through my mobile and onboard cameras front and rear to record off road trips ect ect. I am learning as I go so I am sure as long as I dont flood the car the system will keep evolving as time and knowledge allow.
Rich
Rich
