Repair or scrap / break
25 Oct 2022 11:53 - 25 Oct 2022 20:47 #245573
by Paul4A
1999 T registered Jimny. Early G13BB SOHC engine.
Replied by Paul4A on topic Re:Repair or scrap / break
No one got any suggestions?
I’m concerned with search engines as for instance if I use eBay and put in the car details it comes up with this Link for the lambda sensor but I’m not sure from the advert itself if it’s correct for the earlier engine
Anti roll bar drop links seem to go from £12 on eBay to £46 Here for one, though I’d replace both to be safe. One is £26 on the BigJimny shop
Paul
Paul
Last edit: 25 Oct 2022 20:47 by Paul4A.
27 Oct 2022 09:33 - 27 Oct 2022 09:42 #245609
by Paul4A
I’m told by the supplier that this lambda sensor
simssuzukiparts.co.uk/products/new-bosch...8986507-suzuki-jimny
will fit though will need the electrical connector changing. It’s not actually listed for my early model.
I’ve just found this YouTube video of someone changing a connector on a sensor.
I noted in the video that he uses a special socket to remove and refit the sensor. Something else I’d not figured on but I see them sold on eBay.
As above, advice is welcome
Paul
Paul
Last edit: 27 Oct 2022 09:42 by Paul4A. Reason: Update on socket
- Thank you received: 1869
27 Oct 2022 13:23 #245612
Replied by Lambert on topic Re:Repair or scrap / break
On my 54 plate Jimny I had to replace the downstream sensor and found the expensive way that none genuine is a lottery. It was the start of only fitting genuine or Gucci standard parts for me. It's worth mentioning this was best part of 15 years ago so things may have improved but I doubt it.
27 Oct 2022 13:45 - 27 Oct 2022 14:09 #245614
by Paul4A
Thanks for the reply Lambert.
I contacted my local Suzuki dealer who said that a genuine lambda sensor is £279 +VAT and is non returnable ( from Germany) so would need money up front. It’s also at least 10 days delivery. That’s ridiculous.
I did get the lambda sensor part number however, as 18213-50G01. EBay finds some around the £100 mark, or slightly less if buying from abroad.
or were you talking about the drop link? My Suzuki dealer sells them, part number 42081A10 for £52 each.
Paul
Paul
Last edit: 27 Oct 2022 14:09 by Paul4A. Reason: Updated information
27 Oct 2022 17:20 #245620
The lambda sensor. Like I said it was a while ago and pricing wasn't that awful.
25 Dec 2022 22:45 #246549
by Paul4A
Merry Christmas all. Just thought I’d advise that the Jimny lives again. All the repairs have been carried out, plus some extra welding found when taken to a different MoT garage and it’s back on the road again. Some of the welding was to improve that done poorly in the past but what’s done is done. Got it back earlier this week and it’s nice to be back driving it again.
Paul
Paul
Time to create page: 2.893 seconds
