Paras red 2002 jimny jlx
  • paradox1001
01 Dec 2018 19:06 #198495 by paradox1001
Replied by paradox1001 on topic Re:Paras red 2002 jimny jlx
Not yet cremator but I plan to do at some point.
  • Cremator1
01 Dec 2018 19:09 #198496 by Cremator1
Replied by Cremator1 on topic Re:Paras red 2002 jimny jlx
Ok cool will be interested to see if they hipo flashes don’t forget number plates and reverse lights done mine and reverse lights give a lot more light
  • paradox1001
01 Dec 2018 19:52 #198498 by paradox1001
I think the problem with the indicators flashing double speed is the leds have a lower resistance and current draw than bulbs
This causes the relay to double flash as it would when you have a bulb blow.
If the leds have a built in resistor then it shouldn’t happen but you can always add a resistor in-line.
I’ll let you know how I get on when I’ve bought and fitted some.
I’ve seen some 100w equivalent reverse light leds I like the look of.
Should be just the things for reversing onto our dark drive.
200 watts of white reverse light might be a bit much for other drivers when reversing out of car park spaces though.
Time to create page: 0.329 seconds
