Kirkynut's Jimny (aka Daddy's Tractor) - The Evolution continues...
  • Daniel30
31 May 2018 16:43 #193097 by Daniel30
Ah ok, I see now how that can save a lot of time, yeah I bet they do i bet they think your parking it there for the sake of it :D
08 Jun 2018 14:35 - 01 Jul 2018 21:41 #193295 by kirkynut
No eBay APP ID and/or Cert ID defined in Kunena configurationI have a few changes planned for Daddy's Tractor.
I want to have some spot lights on the front as the current X-Eng cage mounted lights do no more than the standard full beams. I used to have a cheap set of Ring Driving Lamps on my SJ and they were superb.
[img
I am therefore going to buck the trend for LED light bars and go for another set of those at £20 from Halfords! It doesn't matter if they get smashed and they might be longer lasting than cheap LEDs.
I have therefore bought these spot light mounting brackets:
[img
from here:
I had to send a pair back as they were welded wonky but the eBay seller was good and sent me a good pair quickly.
I then plan to put the X-Eng cage mounted lights on the back facing down and wire them to come on with the reversing lamps as my drive can get quite dark and the standard reversing lights don't light the way much.
I'll likely have them switched as well so I can use them as work lights.
Last edit: 01 Jul 2018 21:41 by kirkynut.
08 Jun 2018 14:41 #193296 by X8GGY
(One of mine was slightly wonky too!)
08 Jun 2018 15:04 #193297 by kirkynut
S200KYS wrote: (One of mine was slightly wonky too!)
I could have accepted slightly wonky but these were awful! The new ones are quite straight.
29 Jun 2018 14:56 - 19 Feb 2019 08:12 #193855 by kirkynut
I have fitted my spot lights using this relay wiring diagram:
I got it from this post: www.bigjimny.com/index.php/forum/6-jimny...-wiring?limitstart=0
So thank you Dave!
On the back of the headlamp plug you need to pull the rubber insulation off of the plug its self and look at the back of the plug where the wires are crimped into place. You need the red wire with grey dots on it marked 'drive' on the plug. You'd think it would be the one marked 'pass' but it's not.
I scotch locked onto it. I don't like using them but it was the easiest way to do it.
I have to tidy it all up somewhat as I did the wiring in a field at the Mrs Mum's place.
Photos when I've tidied it all up.
Last edit: 19 Feb 2019 08:12 by kirkynut.
29 Jun 2018 18:23 #193868 by X8GGY
Diagram from 2003 still going strong?! I still have my uses then? ;)
Time to create page: 0.351 seconds
