how long to get up to temp?
  • zukhunter
08 Dec 2010 11:50 #7206 by zukhunter
Replied by zukhunter on topic Re: how long to get up to temp?
mine takes about 15 mins but i put cardboard over the front of the raditor to improve it helps abit not much
i am also thinking the therostate is on its way out
  • Gromit
08 Dec 2010 13:39 #7221 by Gromit
Replied by Gromit on topic Re: how long to get up to temp?
Same as Martin's, mine is warm in about 5 minutes/2 miles.
08 Dec 2010 18:09 #7241 by facade
Mine will blow warm air in about half a mile, the gauge is up in about 2 miles, definitely reads normal in 4 miles, even in the -10.4 degrees we had yesterday.
Standing on the drive it takes 20 minutes to get up to temperature though.
Sounds like thermostats are stuck open.
On the twin cam the thermostat is under the inlet manifold somewhere at the front.
Looks virtually impossible to change. While you are down there, there is a short steel pipe above the axle that connects to the rubber pipe that goes to the thermostat housing. Mine is as rusty as anything, I'm expecting it to leak any minute, worth checking and changing at the same time.
  • goatboy
20 Dec 2010 07:31 #7832 by goatboy
Replied by goatboy on topic Re: how long to get up to temp?
Quick update...
I ordered a new thermostat and went to replace it on sat...
the old thermostat wasn't there! Well the rubber gasket was pretty much all that was left.
Can only assume it got stuck closed at some point so it was ripped apart to allow water to flow and never replaced.
New one now installed and up to temp much quicker!
  • bertbuckie
20 Dec 2010 07:57 #7833 by bertbuckie
Replied by bertbuckie on topic Re: how long to get up to temp?
roflmfao @ no stat!
Mine takes about 10 mins if I dont move....or 3ish miles when moving......remembering its -8 outside :D
20 Dec 2010 13:52 #7844 by ooky_123
bertbuckie wrote: roflmfao @ no stat!
same as above ...
Former owner of Little "Ooky", who has now started a new life in Shetland
Time to create page: 0.157 seconds
