Re:Jimny Clutch adjustment seized
10 Feb 2023 09:20 #247499
by LM42
Re:Jimny Clutch adjustment seized was created by LM42
Had put the metal sleeve bit in vice, and use pump pliers to turn the knob, back and forth, adding oil to it, did free up, for me
Sent from my 2201116SG using Tapatalk
15 Feb 2023 15:41 #247638
by facade
Replied by facade on topic Re:Jimny Clutch adjustment seized
I detached mine at the gearbox, and pulled it back up the engine compartment, then got it in a portable vice and wirebrushed the threads used penetrating oil and the water pump pliers to free it up, as LM42 did.
you can hook it on and off at the gearbox end easily enough.
