Re:Re:Philips Dome head Set screws/ self tapper
05 Nov 2022 07:06 #245763 by mlines
Does anyone know a source of these. Looking for exact match for restoration (Yes, I know I can get them through BigJimny store, but original Suzuki prices are high and I need a lot)
M6 X 15mm shallow Dome head Philips
Similar 15mm self tapper style shallow Dome Philips
I can see lots of pan heads and cheese heads but the only shallow domes I can find are Hex socket heads..
( You can see we had to cut a slot to get them out)
Sent from my moto g42 using Tapatalk
05 Nov 2022 07:42 #245764 by Scimike
How expensive are Suzuki, more expensive than these?
www.martinrobey.com/jensen-healey/jensen...-and-finishers/10816
I have a local engineering supplier and they have always helped when I've called in with the odd restoration screw/  bolt request. Any local you can try, worth a visit rather than the internet.
The following user(s) said Thank You: mlines
05 Nov 2022 07:49 #245765 by mlines
Suzuki are typically over £1 each which would be ok for a one off but not really for bulk.
My local supplier has socket head versions although that's their published catalogue, I have not gone in store and asked about special order
05 Nov 2022 07:51 #245766 by mlines
Oh and thanks for the link to the taptites , that would be a good option
05 Nov 2022 07:57 #245767 by Lambert
If you're going original are you sure they are Phillips and not JIS, the difference being a small dimple between 2 of the legs of the cross and a shallower point angle.
05 Nov 2022 08:07 #245768 by mlines
They are JIS but that's even more difficult :)
Time to create page: 0.261 seconds
