Clonking noise from underneath on very bumpy ground.
31 Jul 2022 08:46 #244312
by Abudougal
Clonking noise from underneath on very bumpy ground. was created by Abudougal
Jeez I was trying to make that title sound a bit more technical and precise but that's what came out and it's at least accurate.
I changed the oil (05 plate 85K miles) and it was clean as a whistle, very surprised to see no crap on the drain bolt and to celebrate I went for a spin off road, did a few miles up over the hills to check out a loch I've been meaning to visit and no probs at all. Then on the way home I took a very rough track shortcut which caused quite a bit of body roll. On the bits that caused the most sway I was getting a pronounced clonk which I think corresponded with the sway of the cab and only on the very worst bits.
My first throught is a missing bump stop but can anyone think of anything else to look for while I'm under there?
PS: Forgot to take a photo, must do that next time.
31 Jul 2022 12:17 #244324
by LesNewell
Replied by LesNewell on topic Clonking noise from underneath on very bumpy ground.
You might want to check your anti roll bar bushes and links. If you're really unlucky you could have a rotted out body mount like I have.
31 Jul 2022 12:23 #244325
Replied by Soeley on topic Clonking noise from underneath on very bumpy ground.
Have you got a tow bar fitted? Some people have reported the exhaust banging on it.
31 Jul 2022 12:57 - 31 Jul 2022 15:02 #244327
by Scimike
Replied by Scimike on topic Clonking noise from underneath on very bumpy ground.
The clonking I've had and the causes, drove me mad finding them:
Rear exhaust silencer hitting tow bar (if fitted) as Soeley said.
Rear spring lower location cone, I suspect rust was stopping the spring sliding over this producing a knock with a bit of bong thrown in. Lifted car to unload spring, wiggled the dirt free and applied spray grease - problem gone.
Worth a check.
Worth a check.
Last edit: 31 Jul 2022 15:02 by Scimike.
31 Jul 2022 18:15 #244338
by Abudougal
Replied by Abudougal on topic Clonking noise from underneath on very bumpy ground.
Cheers guys, no towbar but I'll have a good look at all those other things.
