Occasional click when turning left or straightening wheel
- Jingojimny
15 May 2022 18:00 #243320
by Jingojimny
Occasional click when turning left or straightening wheel was created by Jingojimny
Hello. I just got a gen 3 jimny 2004. I was driving around and hit a pothole pretty hard. Since then there has been a knocking noise coming from the front left whenever I turn left or straighten out the wheel. Does anyone know what could have happened?
- Thank you received: 1992
15 May 2022 18:37 #243321
Replied by Lambert on topic Occasional click when turning left or straightening wheel
Hard to say with certainty but I would have it in the air on stands and give everything a good prod and rattle and confirm that nothing is obviously loose. It's possible that there was an underlying issue that has come through but without careful inspection it's hard to rule things out.
- Thank you received: 667
15 May 2022 21:33 #243326
Replied by DrRobin on topic Occasional click when turning left or straightening wheel
It sounds like a bush, wheel bearing or possibly CV joint. As Lambert says, jack up the front end and feel for play.
Time to create page: 0.324 seconds
