Engine lights, anti theft lights flashing at the same time, car stops
- Moisha
16 Apr 2022 18:24 #242931
by Moisha
Replied by Moisha on topic Engine lights, anti theft lights flashing at the same time, car stops
It was impossible to scan. I checked the cables and they look okeish to me. So I have no clue. I will possibly make an appointment next week and let’s see what happens! I will post for sure the diagnostic so if happens to someone else they will have an answer from my situation:)
- Moisha
21 Apr 2022 18:58 #243041
by Moisha
I went to the garage today, they have no clue what it can be. One thing I realized is that the coolant nearly disappeared, and was nearly empty. Also, my car doesn't start at all now, I needed to leave it on the street. I will try to move it tomorrow, in case that really needs to cool down, but doesn't look that is gonna do it. The mechanic said all pieces seem ok, nothing is broken. and they cannot read anything on the scan, the only solution is to take it to Suzuki and check it there. But honestly, I don't have £120 to take it there and back, to just see if they can fix it, and possibly spending a lot of money, as I think it can be an engine problem and is a 20yo car, so don't know if is worth it. Right now I'm just really sad because I don't want to scrap it, Just paid loads f money for it. but at the same time, I don't want to spend more, And I don't want to sell it for parts as I don't know how to do that also don't want to have it on the mini drive away for a year selling the parts, also don't know if someone will buy it as it is. So completely lost and hopeless, and mad because I don't know whats the problem. What will you do?
23 Apr 2022 07:11 - 23 Apr 2022 07:15 #243076
by Scimike
Replied by Scimike on topic Engine lights, anti theft lights flashing at the same time, car stops
Tough question to answer.
What can be done depends upon ability, spare cash, parts availability and your history with the vehicle.
Coolant level low could be another issue, or it's just lack of maintenance and you have only just noticed. Not starting, assuming the engine is turning over, can be an issue with the immobiliser. This could be related to your initial "everything flashing" problem, again it's likely to be electrical, but difficult for us to offer remote diagnostic help.
You need to determine how much you want to spend / can spend fixing this and how much help you can get for your money if you are unable to do the work yourself. If it's not a lot of help then it could be time to say goodbye to your Jimny.
Still sounds electrical to me, possible ECU / Immobiliser / broken wire, now with possible coolant leak which is usually the head gasket if you can't see fluid on the floor. But then it could be a simple broken cable!
Good luck with it, you can always post questions here if you decide to have a go yourself. Do you know anyone local to you who can help you?? (i.e car enthusiasts), a second set of eyes is always a good start.
Last edit: 23 Apr 2022 07:15 by Scimike.
Time to create page: 0.424 seconds
