New front to back brake hoses
15 Dec 2021 21:30 #240672 by LM42
job for the new year, need to replace the hard lines, one option is flexies , llama4x4 can and do make them , any one with experience with flexies?
Sent from my Redmi Note 8T using Tapatalk
16 Dec 2021 07:28 #240674 by Scimike
Not that common in my experience replacing all hard brake lines with flexible, most tends to go like for like.
I personally don't see any benefits changing the hard line to flex.  It's easy enough to fit hard and the route / mountings are in the correct place to support the hard line, something you may need to change to support the flex, as its flexible !
You do have an investment in tools (flaring tool) and the cheap ones don't work well, so expect £35+ for this tool. Automec sell ready made kits for vehicles that replace all hard pipes, ready to fit, but no direct experience of these also.
​But can't see a reason why not if you want to go flexible, it may even be easier to install. I always DIY my own hard lines and it's not difficult with the correct tools.
The following user(s) said Thank You: LM42
16 Dec 2021 09:31 #240675 by Roger Fairclough
I agree with Mike, plus you may have the problem of inducing a degree of sogginess in the system due to the inevitable "give" in the length of hose you propose. I would stick with pipe but go with a copper based variety.
Roger
17 Dec 2021 17:36 #240700 by LM42
Had a good , informative chat with Dave (llama4x4) going to go with flexies, lot of advantages , no performance issues
Time to create page: 1.214 seconds
