4wd engaging on its own whilst driving
09 Nov 2021 23:01 #239980
by LesNewell
Replied by LesNewell on topic 4wd engaging on its own whilst driving
If the transmission has wound up due to driving on a grippy surface it should just refuse to come out of 4wd until you back up to release the load. It shouldn't pop back into 4wd.
Put it in neutral then jack up one wheel to make absolutely sure you have no load on the transmission and check if it switches between 2wd and 4wd correctly. It does not matter which wheel. The lever should have a positive click is it switches between modes, similar to when you change gear but a bit firmer.
If it's sloppy with no real feel for when it changes between 2wd and 4wd the detent could be faulty. It's pretty rare though. The detent is literally just a ball and a spring so there isn't much to go wrong.
If it is very stiff to move it could be simply that it has seized up due to lack of use. In that case a bit of oil on the linkages and a bit of exercise should sort it.
10 Nov 2021 18:57 #240005
by Paul4A
1999 T registered Jimny. Early G13BB SOHC engine.
Replied by Paul4A on topic 4wd engaging on its own whilst driving
Not an expert on this but what about a vacuum pipe issue. We had a problem a few years ago when we had sudden juddering but can’t remember the details fully. Ours was something like grease in a newly replaced vacuum system
Paul.
Paul.
10 Nov 2021 20:24 #240009
by LesNewell
Only the hubs use vacuum. Issues with that system can leave you with 2wd even in 4wd mode but it can't cause the transfer to jump into 4wd.
- Gix3r
10 Nov 2021 21:11 #240010
by Gix3r
Replied by Gix3r on topic 4wd engaging on its own whilst driving
Its feels to be clicking in to place really well. Ill get it jacked up over the weekend and check. Had a drive about on the wet grass earlier and it was deffinetly changing between 2wd and 4wd properly.
10 Nov 2021 21:18 #240011
by LesNewell
If it worked correctly on grass I'd say it's all working fine. I suspect that your original issue was transmission wind up due to testing on a grippy surface. When you thought you were switching out of 4wd it wasn't actually able to switch due to the wind up. I wouldn't worry about it unless you have problems again.
- Gix3r
10 Nov 2021 22:38 #240018
by Gix3r
Ok thank you for the help
once ive sorted out my brakes ill take it for another drive and update if i have anymore issues with it
Time to create page: 0.261 seconds
