Is it easy to remove the plastic panel from the outside of a door?
  • DrRobin
  • Platinum Member
  • Platinum Member
  • Newbie in Northumberland
05 Nov 2021 11:44 #239876 by DrRobin
Hi,
I have some paint chips on the passenger side door, luckily they are in the plastic panel, but in a recent painting session, the colour match was poor.  I have new paint on it's way, but of course the weather is no good now.
How easy is it to remove and refit one of the plastic door panels?  Will I break all of the clips doing it?  Should I just wait until next year for better weather?
05 Nov 2021 12:36 #239878 by Lambert
Depends on what you use for removing it. I have a pair of reverse action trim pliers and am usually quite successful. The plastic wedge type things I find more often than not kill clips but that could be operator error.
  • DrRobin
  • Platinum Member
  • Platinum Member
05 Nov 2021 13:37 - 05 Nov 2021 13:38 #239880 by DrRobin
Thanks Lambert,
Is this what you use?
Do the clips just hold the panel straight in, none on the side?
Has anyone got a photo of the back of a panel showing the location of the clips?
Robin
Last edit: 05 Nov 2021 13:38 by DrRobin.
05 Nov 2021 16:49 #239887 by Lambert
That's the tool. As far as I am aware it's just on the face.
  • DrRobin
  • Platinum Member
  • Platinum Member
05 Nov 2021 17:09 #239888 by DrRobin
Thanks Lambert,
I have just ordered one, gone for a Silverline, it's a good deal cheaper than the Bahco and all of them were out of stock locally, so it will be a next weekend job now.
  • Reason2doubt
07 Nov 2021 16:35 #239925 by Reason2doubt
Here's a quick heads up where the little plastic clips will be (one clip under each bit of body filler!)
Time to create page: 0.277 seconds
