Radio automatically turning on - is there a way to stop it?
- jimny75
08 Sep 2021 16:34 - 08 Sep 2021 16:35 #238357
by jimny75
Radio automatically turning on - is there a way to stop it? was created by jimny75
Hello everyone, recently took ownership of an SZ5 Jimny (from a Mini Cooper S) and absolutely delighted.
One question (having failed to find a response via search); is it possible to stop the radio automatically coming on when starting the ignition?
Many thanks, Doug
Many thanks, Doug
Last edit: 08 Sep 2021 16:35 by jimny75.
08 Sep 2021 17:27 - 08 Sep 2021 17:29 #238358
by lightning
Replied by lightning on topic Radio automatically turning on - is there a way to stop it?
Well, it must be possible as ours doesn't turn on automatically.
Unless you mean the media screen, and not the actual radio coming on and playing music? The media screen always turns itself on with the ignition on ours but it doesn't do anything just shows the home screen.
l've not tried to stop it from coming on altogether.
Last edit: 08 Sep 2021 17:29 by lightning.
The following user(s) said Thank You: jimny75
- HJdk
08 Sep 2021 18:29 #238360
by HJdk
Replied by HJdk on topic Radio automatically turning on - is there a way to stop it?
In mine i can short press the mute/power button in upper right corner of the screen - that will mute the radio but keep the screen on. But if I long press the same the screen goes off - and it does not come on again after ignition off/on.
Hope this helps...
Hope this helps...
- HJdk
08 Sep 2021 18:30 #238361
by HJdk
left corner
- jimny75
08 Sep 2021 18:45 #238362
by jimny75
Replied by jimny75 on topic Radio automatically turning on - is there a way to stop it?
Thank you, long press good to know.
- Roger Fairclough
- Thank you received: 225
08 Sep 2021 20:32 #238366
by Roger Fairclough
Replied by Roger Fairclough on topic Radio automatically turning on - is there a way to stop it?
Hi Doug,
There are two books that should have been supplied with the car.
The owners manual and the infotainment system.
Do you have these books? If not you are blind to how it all works so you need to ask the person or dealer who supplied the motor as to where they are.
Roger
Roger
Time to create page: 0.321 seconds
