Gen 4 Old an EMU Suspension Lift?
- X8GGY
15 Feb 2021 21:18 #232817
Replied by X8GGY on topic Gen 4 Old an EMU Suspension Lift?
Now then... imagine it with a roofrack fitted! :woohoo:
- Thank you received: 1999
16 Feb 2021 06:20 #232822
Replied by Lambert on topic Gen 4 Old an EMU Suspension Lift?
Exactly. This is why I exhibit caution if I have a load on my roof both on and off road. The last thing I want is for Dreadnaught to feel she needs a little lie down!
16 Feb 2021 11:05 #232838
by 300bhpton
Or put it this way I've trialled 88 Series Land Rovers and Defender 90's. The 90 has a wider axle by a bigger amount than a wheelspacer. But it doesn't perform any better on side slopes real world. Not to any degree that you could drive a course with one vehicle and not with another.
I know in theory a wider stance should give you more stability. But a narrower track may mean you won't need to drive so high up a bank anyhow, and thus less risk of roll over.
Replied by 300bhpton on topic Gen 4 Old an EMU Suspension Lift?
Probably a negligible difference IMO.X8GGY wrote: Which will topple first on a sideslope then?...
The one with wheel spacers (or offset rims) or the one without... considering the CofG is higher with the lift fitted...
- Groundworker
16 Feb 2021 19:25 #232863
by Groundworker
Replied by Groundworker on topic Gen 4 Old an EMU Suspension Lift?
I think there are other factors than just track width, I used to trial and SJ413 and I feel the Jimny is far more stable in side slopes. Leaf springs are a factor, if you do hit a bump on a side slopes then the 'bump' you get from them can send you over. I know I tipped the SJ over far more than I have the Jimny.
I've seen most vehicles tip over trialling but can't remember a classic range rover go over, they can get on some crazy angles and stay upright. I think the soft springing that gives the wallowy ride on the road helps.
A guy in our club has a KAP jimny and the springing is noticably pliant compared to mine, again seems to 'walk' over rough stuff with very little rebound. I find that cross axle can be as bad as side slopes, if you get a wheel in the air and it snatches that can send you over,
16 Feb 2021 23:44 #232869
Replied by jackonlyjack on topic Gen 4 Old an EMU Suspension Lift?
- Groundworker
17 Feb 2021 07:04 #232872
by Groundworker
I went 630 degrees with standard seats and belts and it held me in! You have more trouble with the glass and mud and dust from the floor joining you on the journey!!! At least the airbags didn't go off.
Time to create page: 0.390 seconds
