Radiator Fan Motor alternative - Suzuki Jimny FJB43V
  • lengtzi
06 Feb 2021 10:55 #232524 by lengtzi
Hi there, would like some of the forum knowledge on this. The radiator fan motor of mine has stopped working. Unfortunately my country official Suzuki support have exited my country thus it's very difficult to obtain knowledge or spare parts for my Jimny model.
Was wondering whether there are any alternative fan motor models that can be used instead of the model version seen in the attachment of this post.
06 Feb 2021 11:28 #232527 by Roger Fairclough
Have you checked that the motor is the problem, ie wired it up on the bench?
If you have and it doesn't run then there is no harm in taking it apart. If this involves drilling out a spot weld then do it. Remember, as it is that motor is scrap. Spot welds can be replaced with nuts and bolts. Once inside check out the com. and brushes. these are the likely failure points. Come back when you have it apart.
Roger
06 Feb 2021 17:30 #232542 by Scimike
Sorry not much direct help as my knowledge of Jimny cooling is firmly stuck with the viscose fan on the Gen3.
However in the classis car world a popular upgrade or repair is a universal fan kit. They come in many sizes and cost, below is an example
ebay.us/as81gW
​​​​​​Can you get a suitable one of these?
But as said check everything first
07 Feb 2021 08:09 #232549 by Riccy
Main cooling fan is viscous and run off the water pump pulley, the motor is maybe for the A/C fan?
Time to create page: 0.174 seconds
